Dual Cam WD vs Std WD
Thanks ferroequine, What do you use on your rig?
I dont want to sound cheap, I just want what I buy to work if you know what I mean. If the difference is small then I may opt for the regular WD, but if it in deed performs as advertised then I have no problem with it. Just getting others experiences.
$300 vs. $500, the extra $200 will buy alot of
It depends on what you are pulling behind you -- the larger the trailer, then typically the larger the chance of sway.
I'm using a Reese Dual Cam now. I started out with a friction anti sway bar (the trailer came with it), but it is easier to hook things up with the Dual Cam. The system uses the W/D spring bars as part of the setup, so once you hook up your bars, you're good to go.
It does work as advertised. With our rig, I wouldn't want to run it without an Anti-sway device of some sort, even though it is an Airstream, which are known to be exceptionally stable pullers. You never know when an emergency situation rears it's ugly head.
