lift, tires and wheels
What do you all think i should do to my DAily Driver 97 extended cab f-150 4x4? Im looking for 6 or 8 inches of lift and a good street tire like a bfg or mtr or even a ssr.
When i lift it should i look into put a p inch in the rear? Ill use this alot in the dunes and would like to regear. What would i have to do about the yokes?
Also what lift would you go with and do you think i should take on the task of lifting it myself?
Im thinking of either a 6 inch lift with 33's because the 33's would be easier on the suspension.
If i go with an 8 i would probaly do a 6 inch with 2 inch body
Any ideas would be great.
What tire / lift combination do you like?
Great site and thanks
Ryan
Ryan
thanks for the replies.
Ive already gone though the big truck daily driver stage.
I have a 71 chevy with a 12 inch lift. I live in cali right now so cops give me alot of crapt.
RCD seems like it is a high quality.
The reason i like 33's is because they would be easier on the suspension.
I have a early bronco for hardcore wheelin.
What do you think about installing a lift youself?
I don't think 33s and a 6 inch lift is going to look right. Personally I think 35s are too small for a 6 inch lift.
Anyway, I'd suggest a 5" RCD lift and 35s. Best bang for the buck in my mind.
The 35s are fine with the suspension system of our truck. I have over 20,000 miles on my setup and everything is great. I think the worst thing about lifted trucks is not the tire diameter, it is the offset aftermarket wheels putting major stresses in on the wheel bearings, ball joints, etc. Which is the reason why I stuck to the original wheels.
kev
kev
