Sponsored by: CARiD
Power steering pump
Old Oct 8, 2017 | 08:08 AM
enriched's Avatar
Power steering pump
Just wondering;
I recently replace my power steering pump. (02' f150 4x4)
Upon removal I see that the hardest bolt to remove, ( the one lower and just behind the belt pulley and under the high pressure line), was not there. those who have done this know which one I speak of. Apparently there is a service bulletin that states you can leave it out. I haven't looked for it, just info from other postings.
HHmmm
So that leads me to believe that it was done previously, which is fine. I had put approx. 70k miles on it since owning it. A little disappointed it only went for that, but it is what it is. Could have been worse.
IS it possible that it, ( that one hard to get bolt), was left off during assembly?? I presume not, unless there are others out there whom have found this missing as well that can verify less previous owners and better maintenance records.
Old Dec 20, 2017 | 01:58 PM
DYNOTECH's Avatar
Yep it can be left out. My 97 has has not had that bolt installed for years and no problem. We used to run the p/s pump on our dyno engines with that bolt missing never a problem
