06 SCrew 2WD - Lowering Advice
Black 06 SCrew 5.4L 536HP 2WD Chrome - E-Force - Flow Master FII Duals
I have purchased the Calmax C Arms (2nd hand) and not sure which ones they are... is there any way to tell? I figured out that I have the 4-5 for the rear - I think!
I need to replace all steering/suspension bushings am wanting a mid drop, to go with 305/50R20 in the back and would like to keep 275/55R20 up front. I'm needing better handling and need to get a lower center for what I have added. And here is the rest of the input I would like to know if any of you have encountered...
Will this work if the drop is 3" in the front? With a flip in the back? Brake lines / wheel spacers? WW molding issues? Turning / rubbing issues in the front? Suggestions for struts (leveling Spacers?) / shocks? Steering Column/Drive Shaft issues?
That's where I'm at so far... let me know what you got!
