Outer tie rod binding on coil spring with 6in lift
Hey first time posting anything so work with me. I just had a 6in rough country suspension lift installed on my 07 F150 XLT 4x4 and the outer tie rod is now bolted from the top of the new larger knuckle. Causing it to bind on the coil spring and "clunk" on turns. Very frustrating. So does my rack and pinion need to be moved forward by the shop that should have properly put on the lift? Or can I just bolt the outer tie rod from the bottom. Giving it a steep angle but moving it away from the coil? Please help. And input is much appreciated.
I put a few pictures, let me know what you think. Will work on the Ion in the meantime
Were there drop brackets installed on the steering rack? Some lifts do have brackets that relocate the rack. I think you could get away with mounting the tie rods under the knuckle but I would replace them if they feel loose. Also moving them under will change your toe in so it may need to be aligned again if you move them. Did they install them on top for a reason?? Or just make a mistake?
putting the tierod ends on the bottom of the spindle won't change much since the pivot between the inner and outer tie-rod will still be at the same place.
And you will now get stupid bump steer!
Look to me like it's only the boots that is touching the coil and not the tie rod itself.
I doubt it the tie rod the issue of your clunk.
be sure everything is torqued down correctly and that the upper balljoint isn't binding up, and the cv axle aren't binding either.
