Sponsored by: CARiD
Decisons
Old Feb 14, 2015 | 11:57 AM
stevo198914's Avatar
Decisons
So i need new upper control arm bushings but im tore between just getting new bushing or should i get a complete new upper control arm setup with new BJ. money isnt a issue i just dont want to get new bushing than my bj go bad a year down the road. what do you all think
Old Feb 14, 2015 | 11:59 AM
MGDfan's Avatar
Easy decision - get the UCA - Moog Problem Solver.
Old Feb 14, 2015 | 12:22 PM
Ok thanks i just ordered moog uca with greaseable bj
Old Feb 14, 2015 | 12:29 PM
MGDfan's Avatar
Yep.
Those are the ones.
FWIW - being an opportunist, I suggest that it may be prudent to check all BJ's, tie-rod ends, and swaybar end links for integrity.
If yer parts are originals after ~11 years it may be time fer some R&R. Yer gunna be up in there anyways ...
good luck
MGD
Old Feb 14, 2015 | 12:37 PM
fine_style150's Avatar
To reinforce what MGD said, I recommend you replace your bottom LCA bushing and BJ, because then the top will be tight and firm and the bottom loose. In my opinion, ball joints oughta be done in pairs. I hope you understand what I am saying, I cannot seem to find an analogy for comparison.
Old Feb 14, 2015 | 12:43 PM
MGDfan's Avatar
Old Feb 14, 2015 | 02:50 PM
i completely understand what you are saying there is nothing wrong with the lower control arm though so can i get away with just installing new lower bj?
Old Feb 14, 2015 | 04:02 PM
MGDfan's Avatar
Sure. As long as you are certain those lower bushings aren't worn, like the uppers apparently are.
Check e'er'ting - as this is one job you don't want to have to revisit.
MGD
Old Feb 15, 2015 | 04:08 PM
k9dr's Avatar
I am rebuilding the front end on my '03 FX4, using the Moog upper control arm, energy suspension polyurethane bushing kit to go with it and lower arm, and ball joint for lower.......
k9dr
Old Feb 19, 2015 | 09:57 AM
Yep...just like that
Old Feb 22, 2015 | 03:14 PM
So I had the UCA changed and lower ball joints I no longer have any more squeaks or play in her. Although I do need to replace my struts now because one has a crack that my mechanic found
