Sponsored by: CARiD
Drifting is back
Old Feb 19, 2014 | 08:53 PM
  #31
Thanks Arnaldo, I sure hope so!
Another symptom. As I drive on a road with a turn (especially the passenger side) when there is a bump - even if I slow down- there is a loud clunk. It is very audible and felt in the steering wheel. I can also jerk the wheel back and worth when driving slowly and with enough force the truck clunks pretty loudly on both sides. There is a turn that dips slightly (maybe 30-35 mph along here) and when the road dips towards the passenger side, that side clunks and when the road immediately tilts to the drivers side, that side clunks. It's a pretty loud clunking and over a washboard type surface, the steering wheel jerks around and the clunking is constant.
Old Feb 19, 2014 | 08:54 PM
  #32
I think I'm gonna try to get a video, it might help.
Old Feb 19, 2014 | 10:35 PM
  #33
F man this thread has had so many ups and downs. Can't believe you're still dealing with this. I can't imagine how all this has effected your tires.
I wish I was up there, No joke!
Old Feb 20, 2014 | 06:48 AM
  #34
I was thinking about that Pat. It might have to come down to having a shop pull it all apart and inspect the parts.
Old Feb 20, 2014 | 06:49 AM
  #35
I have never seen anything like this in my life. It's so stressful
Old Feb 20, 2014 | 02:39 PM
  #36
So I took the truck for a small ride after work since it's pretty warm and I could have windows down and not freeze to death
If I hit the brakes, the truck clunks when I stop and lightly release. I THINK I can feel something in the steering wheel when this happens and it would make sense since I can feel the clunks coming through the wheel when each side clunks over bumps. Does that help? I have read that would be a sign of LCA bushings.
Old Feb 20, 2014 | 09:26 PM
  #37
And I want to add this. My sway bar bushings have about 20k on them. They were installed in August 2012. There is a rusty red substance coming out of them where they meet the bar. I do have a spare set. I watched a few videos and it sounds like those however it doesn't explain the sensations in the steering wheel. If I this will help ill give the timeline of noises as well. Truck was perfect beginning of August 2013 once last bj was changed and brakes again. Installed camber kit myself. Brought to ntb it was OK are first. Realized they didn't tighten it when I hit a bridge in the highway. I torqued them down and then squeaking. They said it was coming from the shock. Kept fighting with ntb. New shop fixes alignment dns squeaking is gone but there's a clunk. The squeaking sounded like a creaking noise Ans occurred when the passenger side was compressed. The clunk is felt in the wheel and is audible. I was on the highway the other day and didn't turn the wheel and the truck curves with the road. I think I'm gonna have an ulcer. I can't take thus much longer.
Old Feb 20, 2014 | 10:12 PM
  #38
How many miles are on the truck at this point?
How rough are the roads you drive on average?
You did OEM style rotors right? Maybe one of the bearings is going bad.
clunking only once when braking could also be loose caliper/bracket.
sorry if im being redundant. Im trying to think out loud.....
Old Feb 21, 2014 | 10:18 AM
  #39
Hey no problem. It's helping. I just hit 99k and the roads aren't bad. I did the centric conversion with the 2 piece setup. I can check that stuff Monday but it's a similar clunk the when I hit a bump. I may change the bushings to rule that out. How do I check the various other bushings? Could it be a torn shock bushing? The squeak was coming from thar bushing initially. That tells me the shock was probably twisted since the caster was so far off. If you can assist me on how to test each part maybe I can get this figured out. If I find something wrong I can take a paid weekend and get it fixed
Old Feb 21, 2014 | 12:57 PM
  #40
Shocks have nothing to do with caster on your truck. Caster would be in the LCA bolts. Camber and caster is adjusted there.
as for the bushings. If the are bad the edges of the control arm will rub the cradle at full swing. Thats where the clunk comes from. Metal on metal. I'll see if I can if I can get a picture to help you visualize what im talking about
Old Feb 21, 2014 | 02:42 PM
  #41
I know that but they didn't tighten the lca so it was all out of wack. The shock was twisted as a result. When the alignment was corrected the squeaking stopped but now there's clunking Ans loose steering. Before ntb touched my truck all I needed was the camber kit. It rode awesome.
Old Feb 21, 2014 | 03:18 PM
  #42
Take it back to the performance shop again and be prepared to leave it for a while. They did you well and it's NTB that screwed you over, right?
Old Feb 21, 2014 | 06:30 PM
  #43
The shock doesnt rotate. Its not a McPherson style strut. I dont see how it could get twisted. I think the shop is just blowing smoke up your ***
Old Feb 21, 2014 | 08:42 PM
  #44
George while I agree, it's too far of a drive. I can't be without my truck like that. There's a pretty nice shop a town over from me I might try. All state of the art equipment and building from the looks of it.
Pat they didn't say that, I am. If the shock mounts to the lca and the top is bolted in, doesn't it move with the lca in and out a few degrees. I may stop in to to the shop close to me to see what they say. I need this resolved and I failed inspection due to my exhaust needing to get done. Everything likes to happen at once. I'm gonna be pissed if any of my new parts ate damaged.
Old Feb 22, 2014 | 02:04 AM
  #45
Can't you rent a car for a few days?
