Sponsored by: CARiD
Removing Rear Leaf Blocks
Old Oct 23, 2012 | 11:01 PM
kgraemez's Avatar
Originally Posted by maxpat82
if you want to lower the rear. you couldswap the rear shackle for a 1 or 2" drop shackle.
That's definiatly a AAL.
but the block don't look stock to me.
the one on my truck had a "arm" to the inside so the bump stop hit it instead of the diff.
,5" difference from tire to fender side to side I wouldn't bother with that...it's pretty normal to me...just bounce the suspension and it will change.
So in your eyes the bottom most leaf would be the added one? I was also thinking the .5" could be due to the gas tank being on the driver side. Doesen't really bother me, I just want my wheels to look/fit right.
What's your recommendation on a manufacturer for drop shackles?
Like I said I have 22" f150 Harley wheels on the way and I would like to make them work and am debating taking the bushwacker flares off. I'll take one side off tomorrow and see how It looks.
Cheers
Old Oct 24, 2012 | 04:45 PM
maxpat82's Avatar
The lower one(straight one) is the over load leaf. Normal
On my 2wd i only have 2 leaf + over load
Dont see any issues for the harley 22's
Shackle go with the vheaper you can find from a forum seller
Old Oct 26, 2012 | 07:06 PM
mdhawkin's Avatar
Dont worry about the .5", even the driveway being a little uneven could change that as the suspension will flex a little. I would say if your getting new wheels and 35's put them on first the new tire set may fill up the gap more than you expect. Worry about it after the new setup.
Old Oct 27, 2012 | 04:29 PM
kgraemez's Avatar
That's good advice, thanks. I will do some research as to what Offset I will need to make it flush with the flares. Hopefully someone knows the answer!
Old Oct 27, 2012 | 05:05 PM
06yz250f's Avatar
you are gonna need 4.5" backspacing to even come close to those flares which will not allow you to run 35 with just a level.
