2012 Leveling Kit and tires help
That is one sweet ride..
Originally Posted by rcherry11
Here is my 2" with a 3" block I wonder if I should have got a 2.5" sometimes I think it looks a little to high in the rear.
IMAGE#1
IMAGE#1
Posted from F150online.com App for Android
Originally Posted by russ10screw
Quote:
Originally Posted by Uin2it
Initially I did just the front level too....but something just didn't look quite right. It was dead level looking at profile view...but at any kind of angle it just jumped out at u that the front sat nose high. The extra 3/4" in the back fixed that prob!
Do you have to do a bigger block in the rear after doing a AS 1.5" kit: NO
But I'd recommend at least a 2" replacement block.
Keep in mind the AS1.5" kit will give u 2" of measured lift!
Yep, the spacer is the same they used on the 2004-2008 models which gave those ones 1.5" of lift. But the dimensions of the spacer is exactly the same as the 2" spacers from the other level companies.
Your truck looks nice...I just bought a 2012 Platinum SuperCrew and hate the rake it has. Was thinking of getting the 2" Daystar on the front to level it out. Yours looks just about exactly how I would like mine to sit. What brand did you use?
