Sponsored by: CARiD
2011 lowering help??
Old Apr 25, 2012 | 12:48 AM
kelley350x's Avatar
My 2011 sCrew sits only 1" higher in the rear than in the front and I like it with the 1" rake but I want to lower the whole truck 2-3 inches. Most kits I have found were like a 2-4 or 3-5. I do not want to end up with the rear end lower than the front but I am afraid If i go with one of the two standard kits this will happen.
What do you guys think about using the 2" drop shackles for the rear and the DJM 2" Lower control arms on the front? I am thinging I want to try something like this and if I dont like It the only money I have wasted is how much I spent on the rear shackles. Plus if I end up pulling them and going with the rear flip kit I can resale them and not loose all of that money.
I am running 305/45r22's on factory limited wheels, will I have any clearance issues in the front with the 2" LCA?
What are my other options?
here is a link to the LCA
http://calmaxsuspension.com/djm/products/ca3209-2p/
here is a the truck with the stock size tires on the wheels.
Old Apr 25, 2012 | 01:00 AM
EsJayEs's Avatar
The smart solution would be Ground Force shackles in the rear (because they include a pinion shim), and Belltech struts up front. The struts will allow you to adjust the height to suit your taste. That's the setup I settled on after playing with a few options on my truck. I maintained the 2" of rake so the steering would feel tight, and the truck won't squat when trying to use it as a truck.
Also, the rake should be closer to 2" with the truck unloaded and on level ground. Judging by your pic, it looks like a 2" rake to me.
Old Apr 25, 2012 | 01:08 AM
kelley350x's Avatar
thanks for the info, i just found the struts http://www.belltech-store.com/shock-absorber-166.html
I have measured from center of hub to fender, from the ground to the fender and from the top of the tire to the fender and every way I come up with 1 1/4" higher in the back.
Did your truck have a spacers between the spring and axle? Mine does not???
Old Apr 25, 2012 | 01:35 AM
kelley350x's Avatar
I just found this post and I am interested in going this route.
Originally Posted by T_S_S
Belltech makes an adjustable 2" to 3" shackle. The front you could use Belltech's Pro Coils which is also adjustable 2" to 3".
$296.98 shipped to your door.
found it here
https://www.f150online.com/forums/su...ng-kits-2.html
Old Apr 25, 2012 | 10:12 AM
EsJayEs's Avatar
Only the 4WD trucks have a lift block on the rear axle. If you order the Belltech shackles, you'll want to buy a pinion angle shim too. The Ground Force shackles cost a little more, but when you factor in the pinion shim, they're cheaper. Plus the Ground Force shackles use urethane bushings. Some people claim that you don't need the shims, but installing shackles changes the pinion angle, which can cause driveline vibrations. Not only are the vibrations extremely annoying, but they can damage your U-Joints and pinion bearings. It's worth the few bucks to do it right the first time.
And to clarify on the post from TSS you quoted, the shackle will only lower you 2" in the rear. It's 3" if you have a 4WD because that includes removing the lift block. There is no 3" drop shackle for the 2004+ F-150 because there isn't enough room for one.
It would still be about $300 for the set. If you poke around on Google, you can find the best price on what you're looking for. Or see if TSS still stocks Ground Force. I strongly recommend using their shackles.
Old Apr 25, 2012 | 01:50 PM
T_S_S's Avatar
Former Sponsor
Belltech's Lowering Strut is always the best method for a simple 2" drop. For the rear I can get you Belltech shackles and toss in the shims free of charge. But the EsJayEs is correct 3" can only be achieve with 4WD models.
I only have 2" or 5.5" rear drops available.
Old Apr 25, 2012 | 02:11 PM
kelley350x's Avatar
I have it at the stealership right now and when it gets out (if my bill is not to high) i will be taking you up on the offer for the strut, and shackles with free shims.
pm me a price delivered to a business address in 77707
Old Apr 25, 2012 | 02:18 PM
kelley350x's Avatar
on the 5.5 rear drop, I understand it is a flip kit but what else is involved in the rear kit?
Do you gain 3.5" by flipping and then use a 2" shackle to get the total to 5.5" Or does the flip give you 5.5?
The reason I ask is if the 2" does not get the back low enough i didnt know if i could use the axle flip kit and stock hangers to only make it a 3.5"?
Old Apr 25, 2012 | 02:50 PM
T_S_S's Avatar
Former Sponsor
Do the Strut/Shock package we have $379 with shackles. Shipped.
The flip kit will install similar to this one
http://www.belltech-store.com/extras/docs/BBGC/6440.pdf
Old Apr 25, 2012 | 05:44 PM
EsJayEs's Avatar
A flip kit gives you about 6.5" of drop, and they include a lift shackle to net 5.5" of drop. I had a Belltech flip kit on my truck and wouldn't recommend this method of lowering if you ever want to use your truck as a truck. It's a lot more work and it cripples your truck.
The ideal solution is lowering leaf springs, but only Ground Force makes them for the 2009+ F-150 and they're rediculously expensive. About $1,000 for their 2/3.5 drop kit. They refuse to sell the leafs alone.
