Sponsored by: CARiD
Blow Out Groundforce Lowering Kits
Old Apr 26, 2011 | 10:39 PM
EsJayEs's Avatar
I really like the belltech struts, as their a reasonably priced solution for lowering the front, and gives the user control over how much drop they want anytime in the future. I had their flip kit on until two weeks ago. Good quality, easy to install, but it was more drop than I wanted. 3/5 was too much, so now I'm at 1.5/2.
When I took the flip kit out, I used Ground Force drop shackles. They were more money than the Belltech shackles, but they came with the pinion angle shims. When you add the cost of the Belltech shackles and shims seperately, they were a little more more. I didn't want to risk a driveline vibration, so I got the Ground Force shackles since they were cheaper.
It's a shame that Ground Force is the only company making a drop kit with leafs, and charging so much. I wanted a 2/3 drop, and would've been ok using the 2/4 kit and a 1" lift block or shackle to get the desired height. I just couldn't justify paying that much after seeing how much comparable kits for similar applications sold for.
That's was long answer. Short answer is that I'm happy with the Belltech parts I've used. They offer a good bang for the buck.
Old Apr 27, 2011 | 12:30 PM
T_S_S's Avatar
Former Sponsor
You should not have needed a shim kit with shackles.
Old Apr 27, 2011 | 01:59 PM
38Blackfin's Avatar
TSS-
I need to get back about 3/4" in the rear from my GF 2/4 kit. I need a shackle with 3 1/2" to 3 3/4" center-center bolt holes.
Let me know-
thnx,
Randy
Old Apr 27, 2011 | 02:02 PM
twinskrewd's Avatar
I have lowering shackles on the back for a 2" or 2.5" drop. I'm at 2" right now and I have installed wedges. I also have on the rear dual adjustable QA1 shocks which are about 2" shorter than stock. I would like to drop the rear another inch and drop the front 2". Basically I can get the rear down I just want some springs for the front or a spring/shock combo to drop it 2". Is there a way to purchase what I am loking for?
Old Apr 27, 2011 | 02:04 PM
T_S_S's Avatar
Former Sponsor
Originally Posted by 38Blackfin
TSS-
Let me know-
thnx,
Randy
Randy please call me 888-230-1288 or shoot me a message with more details on your truck
Old Apr 27, 2011 | 02:05 PM
T_S_S's Avatar
Former Sponsor
What is the YMM
Old Apr 27, 2011 | 02:18 PM
twinskrewd's Avatar
Originally Posted by T_S_S
What is the YMM
07 2wd XLT 5.4 thanks for any help
Old Apr 27, 2011 | 02:58 PM
T_S_S's Avatar
Former Sponsor
Belltech makes an adjustable 2" to 3" shackle. The front you could use Belltech's Pro Coils which is also adjustable 2" to 3".
$296.98 shipped to your door.
Old Apr 27, 2011 | 03:05 PM
twinskrewd's Avatar
So they have a 3" rear shackle? If so is the $296.98 for the front coils and the rear shackles? If so I am intrested.
Old Apr 27, 2011 | 03:26 PM
migdaddy's Avatar
Can you hook me up with 2" drop hangers for an 03 2wd screw?
Old Apr 27, 2011 | 03:51 PM
T_S_S's Avatar
Former Sponsor
Yup coils and Shackles
Old Apr 27, 2011 | 03:53 PM
T_S_S's Avatar
Former Sponsor
$170 shipped for Belltech
Old Apr 27, 2011 | 03:58 PM
azmidget91's Avatar
are you sure? because to fit a 2" shackle you have to hammer the seem of the bed over flat....
Old Apr 27, 2011 | 04:04 PM
IR0NS1N's Avatar
My truck came with shackles in the rear, no idea the brand but they have two holes. The truck was in the lowest setting (meaning most drop) and the bed pinch weld was straight.
Old Apr 27, 2011 | 05:43 PM
T_S_S's Avatar
Former Sponsor
Yes I am sure
http://docs.belltech.com/64006401640...006702-888.pdf
