Sponsored by: CARiD
Removing Auto Spring Leveling Kit
Old Apr 5, 2012 | 12:35 AM
Rambo's Avatar
I am removing the Auto Spring Kit and installing the Bilstein leveling shocks. Nuts were orginally provided in the Auto Spring kit for the strut tower. Do I need new nuts or I can I reuse all of the nuts that are in there now?
Old Apr 5, 2012 | 02:26 PM
c1t1d1's Avatar
I think so yes , they should be nylon lock nuts. You should be able to reuse them and re torque them.
Old Apr 5, 2012 | 02:44 PM
canadianelbow's Avatar
You are not supposed to reuse the nuts, even nylocks. That said, I would, but I'd use a little thread locker on them to be safe.
Old Apr 5, 2012 | 02:56 PM
jaws12's Avatar
I'm not sure if you are supposed to reuse them or not...However I have removed the nuts on my leveling kit at least 4 times and reinstalled with no problems.
Old Apr 5, 2012 | 03:15 PM
Rambo's Avatar
Do you guys know what size nuts these are that hold strut tower?
These are the ones I am referring to in step 8. It says: Reinstall the strut back in the upper strut tower and start nuts on the three studs that extend through the tower. Use the nuts provide in the kit. Torque to 35 ft. lbs.
I am assuming you need to reinstall these nuts even without the leveling spacer, correct?. So I might as well use new nuts. Mine look a little rusty.
Old Apr 5, 2012 | 03:18 PM
Rambo's Avatar
The directions say the upper strut nuts are 15 mm. So if I go to the hardware store and get any 15 mm nuts, they will work?
Old Apr 6, 2012 | 12:43 PM
bluegreenf150's Avatar
I'm not sure what size hardware you need or if you need them at all, but they say grade 8 zince plated nylock nuts on their website. Hope this helps.
http://www.jamesoaksenterprises.com/...autospring.htm
Old Apr 6, 2012 | 05:57 PM
Maybe. What they are referring to is the wrench size you need to use to remove the nut. They are likely a M8 nut. But metric nuts can have different thread pitch. The easiest thing to do it to go to the store, with wrench in hand, and in the parking lot, remove the nut you want to replace. Go inside, and run that nut over a bolt they have on hand to confirm its size.
Of course remember to re-install the nut you removed for the drive home....
Old Apr 22, 2012 | 11:03 PM
Rambo's Avatar
Thanks, guys. I looked into getting some new nuts, but it was either too expensive ($10+ a piece at Ford) or I wasn't able to find any before the scheduled install. The original nuts were reused. Auto Spring is gone, Bilstein 5100 shocks are in and it rides like a dream now.
Old Jul 19, 2012 | 03:44 AM
DChan415's Avatar
Really? The Bilsteins gave you a better ride over the autospring kit? I thought the 5100's were stiffer shocks.
Were your old shocks really worn?
Old Jul 25, 2012 | 08:05 PM
x2, I found after a year of ride experience the 5100s were a big mistake for a daily driven truck.
And my Bilstein kit for my old 2004 truck came with all necessary hardware, including nuts.
