Sponsored by: CARiD
suspension prob
Old Feb 14, 2012 | 09:30 PM
06yz250f's Avatar
06yz250f's Avatar
got a picture of where it rubs and an entire pic of the truck?
Old Feb 14, 2012 | 09:38 PM
camunaro's Avatar
hahaha, im pretty computer illiterate if you cant tell.....
gimme a few and ill try and figure it out.....thanks so much for your help. i dont have a pic where it is rubbing but i know it is on the front valence ( sp? ) the plastic piece under the bumper....
ill send the pic of my truck to my photobucket thing again...
Old Feb 14, 2012 | 10:02 PM
camunaro's Avatar
http://s1059.photobucket.com/albums/t439/camunaro/
Old Feb 14, 2012 | 10:15 PM
camunaro's Avatar
[IMG]http://s1059.photobucket.com/albums/t439/camunaro/?action=view&current=8.jpg#!oZZ7QQcurrentZZhttp%3A %2F%2Fs1059.photobucket.com%2Falbums%2Ft439%2Fcamu naro%2F%3Faction%3Dview%26current%3D2.jpg
[/IMG]
Old Feb 14, 2012 | 11:28 PM
04lariat711's Avatar
Those coilovers can definitely be cranked up a couple inches which will help. I can't tell from your pictures if its rubbing anything inside or not. What I did was turn the wheel into the valance and trimmed about 1/2 inch above where it was rubbing. Hasn't given me problems since. That's a good looking truck man.
Old Feb 14, 2012 | 11:54 PM
camunaro's Avatar
thanks alot....
BUT.... early dec it had a hit and run done to it, and today some bozo who couldnt drive hit my front end....grrr...
nothing insurance wont fix thou.
cranking the coilovers, how exactly can i do it. i have the "wrenches" but should it be on a hoist, or just sit on the ground, will i need another front end alignment? when i called procomp, they said i should not adjust them, but never really gave me a reason why, just said that they had them set for best performance coming from the factory. i honestly wasnt getting anywhere when i was talking to him, mostly because im new at this and really wasnt explaining myself as well as i should have i guess.
since the pics i have added recon smoked tail lights and third light, this spring / summer ill complete the front with HID's i think.
Old Feb 15, 2012 | 03:55 AM
I don't have my coilovers installed yet but I'm thinking you want the front end on a jack. It should make it a lot easier. But I do know for sure you are going to need an alignment after. I'm not sure why the guy would have told you not to crank them up? If they weren't supposed to be done, they wouldn't have made them adjustable. It will most likely make the ride a little stiffer, but that's no reason to say not to do it.
Old Feb 15, 2012 | 11:22 AM
fine_style150's Avatar
nice truck, i have the same rims, crank the coliovers man! im on 33"s and 2.5" lift and i'm not rubbing i did trimming to the plastic only so the coilovers adjusted to 2" should be clear and free
Old Feb 15, 2012 | 03:01 PM
HighOn22's's Avatar
You will want to lift the truck up and take all tension off the coilovers. The tool stated in previous post will be needed. The top circle nut will need to be losened, then tighten the lower round nut. This will put more tension on the spring which will stiffen the front and not allow the front suspension to settle when you let it off the jack. The top nut will then eed to be tighten aganst the lower nut. I'm not sure how far to tighten to get you another 1". Some one on here with coil overs sshould be able to help out. If you lift the front you will also need to lift the rear.
I believe almost everyone on here whom has a leveling kit or lift has trimmed there front vallance.
Old Feb 15, 2012 | 05:53 PM
camunaro's Avatar
thanks for the help everyone. as soon as i can get my hands on a hoist and wheel alignment machine ill try to adjust the coilovers,
thanks for the positive feed back about my truck, i have a few more ideas what im going to do next....
Old Feb 17, 2012 | 11:53 AM
def. in the meantime trim the plastic to avoid most of the rubbing, i did that and i only rub at max scenarios like at pitchs and angles but regular day to driving is just as normal stock wheels
Old Feb 20, 2012 | 01:25 PM
camunaro's Avatar
Hey thanks for the advice. as soon as i get a chance ill have to do something
Old Feb 21, 2012 | 03:14 PM
sure thing, i used a dremel with a cutting wheel. i put masking tape down as a guide and for protection. after the cut is done sand it down so it looks pretty
Old Feb 27, 2012 | 12:07 AM
camunaro's Avatar
thats a great tip...with my skills ill prob hack it anyway, thats my delay
