Sponsored by: CARiD
suspension prob
Old Feb 14, 2012 | 02:04 AM
camunaro's Avatar
suspension prob
Hey everyone. im having serious issues with my pro comp stage 2 6" im running 35x12.50x20 rubber and im getting serious rubbing. the offest is suppose to be 18mm
is anyone having this issue? if so what can be done the stop this....2.5 level kit body lift?
please help....and post some pics of your ride
thanks
C
Old Feb 14, 2012 | 03:39 AM
04lariat711's Avatar
Do you know where it's rubbing? If it's just the lower valance that can be trimmed pretty easily and still look good. I'll try to post some pictures of that on mine. If you have a stage 2 lift you can crank your coilovers up an extra couple inches. I would not suggest adding a spacer if you already have a 6" spacer, but if you do you wouldn't be the first.
Old Feb 14, 2012 | 03:48 AM
If these pictures work, they're kind of crappy, and the trim I did was crappy, but I honestly didn't care how it looked and it does show what needs to be done. You can make it look as pretty as you want.
Old Feb 14, 2012 | 07:46 AM
06yz250f's Avatar
post pics.
you can crank your coil overs to get additional lift. you will need an alignment afterwards
Old Feb 14, 2012 | 09:08 AM
camunaro's Avatar
thanks that is where it is rubbing, im trying not to trim, plus if its that close im worried it still wont be enough if i go off roading and it will rub something off. strange i did extensive research before i did anything and i still failed....haha
Old Feb 14, 2012 | 09:10 AM
As 06 said post pics of your front end. If you have aftermarket coilovers you can crank them to give you more clearance.
Old Feb 14, 2012 | 09:21 AM
camunaro's Avatar
Originally Posted by 06yz250f
post pics.
funny you say that. i called procomp awhile ago, explained everything and they said that nothing could be done. i knew they werent telling the truth on that as ive read and researched alot before i did the lift.
and ive seen / PM'd other people with the same set up and they have had no issues with rubbing. ive also parked beside a truck with a 6" ( althou it was a f-250 ) his looked so much higher then mine.
im totally lost. i know it is rubbing on the lower valence ( sp?) but my concern is when i go off road that it will hit other places as well
any idea how to crank the coilovers up?
thanks for your replies
Old Feb 14, 2012 | 09:23 AM
camunaro's Avatar
ill take some pics later today once the sun comes out
thanks for your help
Old Feb 14, 2012 | 10:48 AM
To crank them you need a special tool, I'm sure someone else will be able to tell you what it's called. As soon as you post up pictures someone will let you know for sure if they can be cranked. Just from my own experience, after I trimmed my lower valance I've had no problems whatsoever with any type of rubbing at either wheel lock, on or off road, backing up or in reverse. Again, just my experience with my personal truck.
Old Feb 14, 2012 | 10:50 AM
"backing up or in reverse?" Haha you guys know what I mean. I need to learn to proofread.
Old Feb 14, 2012 | 01:38 PM
06yz250f's Avatar
I'd assume you would use a spanner style wrench to adjust it (someone will probably prove me wrong) or you can take it to a shop to get done. I didn't have coil overs on my f150 so can't give you a 100% way to do it.
an f250 with 6" will sit a lot higher. My f250 with a 2" level and 35's hood height was w/in an inch of a 6" lifted 09 f150 on 35's.
Old Feb 14, 2012 | 02:59 PM
sampson01's Avatar
Its called a spanner yes and the trimming will be one way to fix it. Cranking it up will possibly help also.
Old Feb 14, 2012 | 08:37 PM
camunaro's Avatar
sorry for the delay, as if my luck isnt bad enough, i was in a small fender bender today.
anyway i cant seem to load up the pictures
Old Feb 14, 2012 | 08:42 PM
06yz250f's Avatar
upload to photo bucket and copy the [/img] code below the picture and paste into a reply.
Old Feb 14, 2012 | 09:29 PM
camunaro's Avatar
http://s1059.photobucket.com/albums/t439/camunaro/
this is the link to the pictures i hope this helps. i tried to just insert the pics but for some reason it wont show....sorry
