Sponsored by: CARiD
Coil Spring test?
Old Oct 22, 2011 | 04:48 PM
MLD's Avatar
MLD
Coil Spring test?
What's a good check on the condition of your front springs?
I replaced the front shocks last year, and found driverside was bad; other was fine.
You could tell it right off the bat, the *difference* after the replacement. But due to the subjectivity of our experience,( philosophical) the subtle drift into something less "better" escapes the attention; you dont stand up and take notice of a leaky shock.
I suspect my springs may a bit' south' after a ride down an undulating road with peaks and valleys. Real wavy like.
Any tricks or thoughts?
Thanks,
MLD
Old Oct 23, 2011 | 10:08 AM
54regcab's Avatar
That's why when it comes time to do mine I'm just going to get the whole assy. No compressing springs and it's $100 per pair more than just the shocks.
Old Oct 23, 2011 | 05:34 PM
MLD's Avatar
MLD
Good idea.^
One day my dad took his 94 f150 springs out and he said, "you should have seen the difference in length." My comment, "wow, the old a lot shorter." "Nope, the other way around, it was about a 1/4 longer in length."
All in all I don't how you could know unless the ride was real bad.
Old Nov 27, 2011 | 11:38 AM
MLD's Avatar
MLD
Well, I took the truck in to get it measured, and it is only 1/2 inch low on drivers side. Said new springs would give a one inch lift over where you are now, but you're good for now.
Leaf springs squeak and they said I need new "spacers" in there. They're worn.
I'm towing soon and I thought a checkup would be prudent.
Old Nov 27, 2011 | 12:16 PM
tbear853's Avatar
My '77 still has originals and no rear squeaks, no front sag.
Good shocks that actually dampen do increas the life of springs by curbing the oscillations.
