Sponsored by: CARiD
6" Procomp stage 2 - not level!
Old Sep 7, 2011 | 04:37 PM
Johnie_West's Avatar
Okay what gives with the 2 3/4" aluminum rear block they send? The rear sits a good 2" lower than the front. Yes I also used the stock block too. Am I supposed to crank down on the front struts to lower it to the same level? Procomp told me they were preset and not to adjust them. Help me out here please.
Old Sep 7, 2011 | 05:00 PM
pstennisace's Avatar
You may just need to purchase a 4.5 or a 5" rear block. My BDS came with a 5" and the rear is about 1.5" higher than the front, I need to slap a level on it!
Old Sep 7, 2011 | 06:19 PM
Yeah that's what a local off road store said too. I ordered the BDS 5" block. That's still not gonna level it. Guess I'll have to crank down the front stuts too anyway. That sucks! I wanna go up not down. lol. I'll put a 3" body lift on it too. That might get it high enough to make me happy.
Old Sep 7, 2011 | 06:33 PM
atr04screw's Avatar
If the 5" block doesn't get it high enough, then you can do a 1.5" add a leaf or 1.5" lift shackles for some extra height.
Old Sep 7, 2011 | 07:06 PM
Thanks for the tip. I'll look into the add a leaf and the shackle options.
Old Sep 7, 2011 | 08:28 PM
Big_Smokey's Avatar
id probably adjust the coilovers....mine sites level. maybe not in the pics ,but it is by the tape. i have the stage II also
Old Sep 8, 2011 | 05:13 AM
fx4 for life 79's Avatar
Yeah pro comp on the 04-08 don't sit level. I ran their kit on my old 05 with a 4.5" block and 1.5" aal and that made it sit dead level
Old Sep 8, 2011 | 10:44 AM
jerhelo's Avatar
This is the same setup I am running right now. My front fenderwell clearance is about .5" higher than the front now. Sits perfectly level. I am considering new Skyjacker Leaves but that project is on hold. Good Luck...
Old Sep 8, 2011 | 07:41 PM
I took out the stock block and the procomp aluminum block and put in a BDS 5" block. Only have to adjust the front down 1/2" now and it's all good. I'm way OCD on that stuff. I appreciate all the advice. Thanks
Old Sep 8, 2011 | 07:42 PM
Now doing a 3" body lift. Dang! Gonna need bigger tires now. It never ends does it?
