Coil-over and leveling kit Question
I'm gonna be picking up some newer coil-overs for my 4wd soon and right now, my worn out coil-overs have a 3" leveling kit on them and sits 1" lower in the front.
I'm stuck between keeping the 3" or buying a 2.5" kit to replace it.
So should I replace the 3" kit with a 2.5" because I'm getting newer coil-overs?
If I keep the 3" kit I'm probably going to gain the 1" to level out my truck that I want, but my angles will be a little extreme.
If I buy the 2.5" kit, my truck will probably have the same stance, my angles will probably stay the same as they are now, and I will just have newer coil-overs.
So I'm debating on what to do.
I had a 3" kit on my truck with add-a-leaf in rear for 2 years...I ran 35" BFG'S in the winter no problem...after about 20,000 miles I could tell my ball joints were ready to die...
I replaced front controls/joints and lower joints and did the outer rods while I was there...all moog parts from advance...my first problem was that the alignment shop said I needed a camber kit...(which I never needed before)...Then after I put the moog camber kit on and they did the alignment I noticed the truck would make noise...which I believe was the spring and the upper control arm hitting...they told me there was nothing they could do...since then I replaced them again because the boots were getting destroyed...thankfully they have a lifetime warranty...and installed a 2 1/2 "spacer...then I told the new alignment shop to try and do it without the camber kit...It now drives like **** and still makes noise...
I believe that the moog upper arms/lower joints might not be exactly the same as the OEM Ford arms/joints and this may be my problem...I might just spend the $350 to find out...
just not ready to spent $$$$ on $1,000 shocks or uniballs...not yet...
what ya'll think???
what ya'll think???
How did you know your ball joints were wearing out? Did they make a sound or did they just ride rough?
