4 inch lift question
Well guys like the title says I'm thinking about a 4 inch lift on my f150 check album for pics but I was wondering if the rims I have will work they are 18x9 with 18mm offset. I also was wondering if I can still use my airbags that I have installed or will I have to get rid of them? Sorry for the lack of proper grammer I'm on my cellphone. Input would be much appreciated.
Depending on what lift you go with, your current wheels might work. Some lifts, like rough country, require a negative offset. And yes you can still use your air bags. Also, you can get a 6" lift for about the same price as a 4" lift, so thats something to think about if you ever want to get a bigger tire in the future. With a 4" lift the max is about a 35" tall tire. If you go 6" then a 35" tire will still fit and look good, but you can go with a 37" tire if you want to.
