What to do?(lift?)
Don't go cheap
I don't have any experience with body lifts, but don't do a spacer for the front. went that way and regret it. it tweaks the front suspension way too much. after three months i had to replace a hub assembly, and now a year later my tie rods are going bad. It also steers kinda of sloppy now. If I could do it again, I'd just wait until I could buy a real lift kit.
They don't make any 3" suspension lifts for our body style 4wd trucks. You could do a 3" body lift, but if you are going to be paying someone else to do it then it won't be worth it since time and labor for the install will run you about $900. I would look into the 5" rough country suspension lift. It's good quality and you can get it for under $1000. If money isn't a big concern then go with the 6" fabtech.
you can crank your front torsion bars for a couple inches of lift to level it. then your next step for larger is a body lift or suspension. if you can afford it i'd go with a suspension lift.
