Sponsored by: CARiD
does my axle look right?
Old Jun 25, 2011 | 02:23 PM
RandomHero34's Avatar
i installed a 5.5 PC block last weekend and makes the axle look like its on an angle. im not sure but is it supposed to look like this? Is the block supposed to be straight up and down?
Old Jun 25, 2011 | 04:30 PM
06yz250f's Avatar
some blocks are squared on all sides, others have a pie cut out of the bottom to point the pinion towards the transfer case. if there is no binding i wouldn't be worried about it.
Old Jun 25, 2011 | 04:41 PM
fx4 for life 79's Avatar
What this retard said^ haha jk. But as long as it is running fine I wouldn't worry about it
Old Jun 25, 2011 | 04:42 PM
06yz250f's Avatar
^^ pole smoker.
Old Jun 25, 2011 | 04:55 PM
Barryrod's Avatar
Putting the block without extending the drive shaft will change the angle. Simple geometry really.
Old Jun 25, 2011 | 05:00 PM
06yz250f's Avatar
^^ extending a drive shaft won't change the angle any. the two mounting points (transfer case output and diff) are at fixed points so angle is standard. what will change it is fixing the rear pinion angle and pointing it towards the TC output.
Old Jun 25, 2011 | 05:18 PM
mdhawkin's Avatar
The pie piece is for your bump stop. However you can get tapered and non tapered lift blocks, any clue which ones you got - guessing tapered?
Old Jun 25, 2011 | 07:11 PM
06yz250f's Avatar
i meant tapered. word wasn't coming to me so pie piece cut out seemed self explanatory, but nooooo you had to call the rhombus shape bump stop a pie piece
Old Jun 25, 2011 | 10:01 PM
Galaxy's Avatar
Your shocks are upside down BTW.
Old Jun 25, 2011 | 11:08 PM
jerhelo's Avatar
looks fine to me, the larger procomp blocks are tapered...Should angle the axle slightly....
Old Jun 26, 2011 | 09:04 AM
cool, thanks guys. does it really matter what way the shock is installed? my stock shocks had the rod end up, so that is how i installed the bilsteins.
Old Jun 26, 2011 | 09:33 AM
HYPO's Avatar
No it doesn't matter which way the shocks are mounted. Some people make a big deal of things like this, however if it really mattered, the manufacturer would label them and probably include warnings in the packaging. I have never seen either of these things. BTW if you have tapered blocks, it does matter which side you mount them on, because it matters which way the taper is facing. Yours have the tongue on them which is to contact the bump stop, therefore since they must face inward it probably forces you to orient the blocks properly.
HYPO
Old Jun 26, 2011 | 09:35 AM
Big_Smokey's Avatar
just looks weird. normally you see the body on the up side....at least every shock ive done. Thats how they are factory also.....at least on all the vehicles ive messed with.
Old Jun 26, 2011 | 11:47 AM
Galaxy's Avatar
Hero...I may be wrong, been a while since I looked but I'm pretty sure you stock shocks had the body up/rod down. The stock shocks just have that big plastic boot on them that make it look that way.
I also respectfully completely disagree with HYPO. The shock instructions should have told you which way they mount. But if you look at your Bilstein label on the shock, yours is upside down. That's not a coincidence. And yes, it does matter. The valving, fluid flow, and internal design is most definately designed to work a certain way. The shock is also safer the other way...that hardened steel rod will take A LOT more of a beating than the body will. Thus, tucking the body up unde the truck is better and more protected.
jerhelo's Avatar
HYPO
Actually some shocks label and dictate the mounting direction, my MX6 shocks for the rear state to put the body on top. I want to put the body on the bottom because I am concerned about tearing the valve off on something like a rock or something...
