Sponsored by: CARiD
~ Level kit dissapointment
Old Jun 21, 2011 | 08:04 AM
  #31
UNC Lariat's Avatar
Adjust for ride comfort? Interesting, just exactly how does this work? Adjust on the go? Or in the shop followed by a re-alignment?
If you get the My Ride kit, you can adjust shock stiffness as you go down the road. With the kit, you get a compressor that fits underneath your truck and a controller that is in cab that allows you to change the settings.
Without the kit, all you have to do is turn the adjustment **** on each shock. It takes a little longer this way but either way, you don't have to go to a shop to get it done and you don't need a realignment after making those adjustments.
Old Aug 10, 2011 | 10:09 AM
  #32
vtjenkins's Avatar
Originally Posted by funtuff
Stealth, I just realized what you said. Yes the truck was off the ground. :-)
When you say "off the ground" do you mean at the shop on the lift, immeadiately after installation?
If so, would you take a pic of the angles on your truck as it sits on level ground?
Thanks in advance
Old Aug 12, 2011 | 01:04 AM
  #33
poolboy1191's Avatar
Thanks in advance
Yes, if you look closely, you can see the metal feet that the air lift uses. It is sitting on the "strengthened" part of the frame...
I would also like a pic of the angles on the ground....
