Sponsored by: CARiD
2wd shocks to 4wd shocks?
Old Apr 20, 2011 | 07:34 PM
2008_XL's Avatar
Originally Posted by Ford12508
Umm you have a lot of options, and 4x4 shocks should be the same as 4x2 shocks up front.
OEM 4x4 shocks are longer than the 2wd version. That's why the 4x4's sit up about an inch higher in the front.
Old Jul 31, 2011 | 06:50 AM
bay150's Avatar
Originally Posted by Buxton91
Oh I see you have the old style fabtech that came with the 6" struts? The new style fabtech comes with a 6" spacer. Bilstein does make a 6-8" strut that would replace those fabtechs and allow you to crank 2 more inches to sit at 8" high.
I too have a 2wd with a 6" fabtech lift. I am debating if I should put my 2" spacer back onto my strut or replace with a 5100. I found a site that asked what my lift was and then suggested a 5100 that would fit it. Im not sure if that site was right though.
its: http://www.summitracing.com/search/b.../?autoview=SKU
You are saying a longer than stock 5100 will allow me to crank 2" more out of my setup then and not use a spacer. Is that a better option that the spacer?
