Do Hellbent leveling kits rub?
so with the 2.5in hbs kit i can put 35x12.50s on? cant use my stock rims,(20x8.5) kinda dented the lips and tore half of one off. oops. So im wanting to use an 18x9. unsure of correct amount of backspacing to use. going to get mud grapplers to protect the new rims. want to stay with at least a 35 cause i am going to do a body lift in a couple of months. sorry for writing a letter.
so divide cm's by 2.5 = inches
HYPO
From what I have read on here, it seems to average about 2 hours to install for the home installer. I was quoted $125 yesterday for an install so I would say that is about right.
Cany anyone confirm that the strut bolt pattern is the same from 04-08 to 09-11? The CS rep for HBS is claiming that they are, even though everyone lists different kits for the two different models.
I just installed the HBS 2.5" kit friday night. It took about 1 hour on the driver side and about 20 minutes on the passenger....the driver side took longer just getting the tools together and running to the auto parts store after i was halfway through the teardown to get a 30mm deep well socket. All in all it was a very simple install. If you go with the HBS kit, the directions are pretty good but they dont tell you to take off the brake line bracket which makes things easier and doesnt put alot of stress on the brakelines
Will post pics once my tires get here next week. Nitto Mud Grapplers 35x12.50x18.
This causes a wider stance. With that setup, I would rub in reverse only at full tilt on the Cab part of the wheel well.. I trimed the fender flares and some black plastic from the well.. and found out that it would still hit where the cab was welded to the firewall.. But the Rub wasn't bad at all.
Now with my 6inch lift.. no rub at all.. so a body lift would help this too.
