Need Some Help- I want to be taller
Ok I am kinda tired of looking at my truck as a almost lowered truck
It is a 04 FX4 with Bilstein 5100s 2" It is leveled but still feels low to me. I honestly am no where near being able to afford a suspension lift at this point. I want to eventually get a 6" lift
I'm a broke college student
I want to get the truck a little higher.
So what are my options? Body Lift, Add-a-leaf? .......
Here she is as she sits now:
I honestly don't know what I want to spend. I am planning on getting 295/70/18 Trail Grapplers w/ MOnsters next. But I don't know anything about suspension besides lifts honestly.
I am just sick of looking at the two guys that drive 2500 series trucks and theirs are much taller than mine completely stock
I just want to get it higher for the looks, yet I still tow a boat a decent bit
Just throw out some somewhat affordable options, I had some major sag towing one of our big 22' boats today at work, I was thinking air bags or an AAL ???
Just some advice from someone who did things little by little and now I'm paying for it.
Don't buy the 295's if you plan on going with a 6" before they wear out. They will look too small, trust me I know.
Don't go with just a Body lift because 3" won't be enough and unless you plan on running 36's or bigger along with the suspension lift you will eventually buy on top of the body lift. Not to mention, gears, tuner etc... You will always want to go bigger. .
Since you tow and you have the itch to do something, get your AAL because that will benefit you in more ways than one. If you don't plan on lifting for a long time go ahead and get your 295's, it will dramatically change the look of your truck and it will appear bigger.
Also on the body lift, like Blackout07 said. You will pay $600 for the body lift and if you're having it installed plan on another $500 at least, most likely more. That leaves you only $3-400 short of a Rough Country 6" Suspension lift.
save for the 6", its absolutely the best bang for your buck. I can already tell you're unhappy with the small lift that the bilsteins gave you, and the most lift you're going to get no matter what parts you use minus a full suspension lift is 3", and I doubt you'd be happy with that in the long run.
Theres tons of deals to be had on quality lifts, new and used, just be patient and spend lots of time looking for the right deal.
Thanks also to Indo who sold me his Diamo Karats as well!
Good luck!
Good point too...thanks to the Classifieds here, I sold my Bilstein 5100's (all four with coil installed), Autospring 2" spacer, front OEM skidplate, and most recently, OEM spring shackles (I have OEM 4x4 knuckles if anyone is interested!!). Come to think of it, I also sold my old chrome badges, PIE adapter, several radios and other odds and ends. There is no reason to sit on these parts as someone ALWAYS has a need for this stuff plus it offsets the cost of the NEW stuff!
i just suggest some bigger tires. i gotta 2.5 leveling kit with 305s on my 04 and my mirrors are about a inch shy of being able to clear over stock 4x4
f150s mirrors. i got more height on my buddys 2500hd and hes got his torsions cranked.
