2" AS wont fit with 6" Pro comp! HELP!
I Have a 6'' pro comp stage I and Tried installing a 2" Autospring spacer tonight... but the spacer turned the strut around completely 180 degrees backwards. That would be fine if i was mounting it on just the stock strut, but the 6" pro comp spacer is angled and wont work backwards. If you are familiar with the strut assembly you will know that the bolts only line up one way.. so I just couldnt figure out how anybody could get it to work. Any body put one on themselves on top of a pro comp spacer? please help.
I actually just looked at the picture of the spacer that Autospring had up. The one in the picture would work... but thats not the one i got. On the one in the picture the holes on the bottom of the spacer line up right up under the bolts that are welded on. On mine the holes are completely backwards from the bolts... anybody follow what im saying?
yeah in the directions it says the strut is rotated for the 1.5 and 2in. kits. i got the 2.5in. kit and i can't really remember but i don't think my strut was turned. i have the standard fabtech shocks though.
I know i know ive heard it all before... but plenty of people have done it with no problems. And i was only going to do it until i can afford dirt logics. But My question is why does the spacer turn the strut around and how have so many people on this website put this spacer on when it turns the strut around. Or did the one they put on not turn it around. Thats the only way I see it happening
ANY spacer kit, wether it be AS or HBS, must be installed between the factory strut and stage 1 lift spacer in order to work properly
should be:
procomp spacer
AS spacer
factory strut
should be:
procomp spacer
AS spacer
factory strut
Well You know.. now that i think about that it makes sense. but doesnt the strut by itself have an angle too? thank you for your imput though
yes (~1.5 degrees), but all AS products have opposite angles to counteract it
no wayyy Fabtech stooped down to that level too ?
Seems like everyone these days are cutting corners short to get an extra buck
