Sponsored by: CARiD
cant seem to remove lower control arm
Old Jul 24, 2010 | 08:56 PM
Tumba's Avatar
If you're trying to save the part for re use, just keep putting Kr-oil, or Marvel mystery on it and beating the crap out of it. If not go ahead and cut it out.
Sometimes it's easier on the sanity just to spend some more $$$$. Remember, the sanity is important
Old Jul 25, 2010 | 07:13 PM
FullerF-150's Avatar
yeah thanks guys, pretty much what i wasnt hoping to hear lol. ive got a mobile heavy equipment mechanic coming over tomorrow to see if he can break it loose with his high-torque impact wrench
Old Jul 26, 2010 | 08:07 PM
well i was able to get them out today; i called a mobile heavy equipment mechanic, and with his zip gun and 3/4" impact we were able to get them out!
Old Jul 30, 2010 | 02:14 AM
midwestoffroad's Avatar
I couldnt get mine out torches and impacts and 20 lb sledge. i took the easy way out cut the bolts and went to the salvage yard and bought another control arm with the stock bolts for 50 bucks.
Old Jul 30, 2010 | 02:16 AM
and as for why they get stuck.
there is a slight undercut to the bolts between the head and the treads and dirt and rust get in there and more or less rust weld the bolt in there. i was able to move mine but not enought to get the dirt back out so it was lock in there tight.
Old Sep 23, 2012 | 10:16 PM
Craignolan's Avatar
I cut off the head of the bolt, took off lca then used on blaster and pounded it out effortlessly by hitting the side I cut. The threaded part won't go thru it. Purchase new bolts and back to install without having to replace arms or bushings. Hope this will help somebody
