Sponsored by: CARiD
cant seem to remove lower control arm
Old May 19, 2010 | 07:02 PM
Big_black04's Avatar
so im working on installing my 6" lift and i cant seem to remove the lower control arm. i got the nut loose and when i turn the bolt the whole thing turns. i dunno if im suposed to hit it out or what.
Old May 19, 2010 | 07:35 PM
StoveTop's Avatar
Hammer... (you probably need a punch to drive it out)
Old May 19, 2010 | 07:40 PM
ok yea i thread the nut back on alil bit and smacked it a couple times with a sledge hammer and it didnt budge i guess i need to hit it harder lol
Old May 19, 2010 | 08:24 PM
so i continued to beat the **** outta them with a sledge and they still wont budge anybody else have any ideas?
Old May 19, 2010 | 09:57 PM
IH8ATTN's Avatar
get a bigger sledge hammer....and a stronger friend.
Old May 19, 2010 | 10:00 PM
thejake1989's Avatar
Like said you need a BFH or (Bigger ********* Hammer)
Old May 20, 2010 | 02:38 AM
i guess i'll just beat the outta it all day tomorrow if i have to lol
Last edited by Bluejay; May 20, 2010 at 05:03 PM. Reason: Do not circumvent the language filter
Old May 20, 2010 | 04:54 PM
StoveTop's Avatar
I am confused as to why the bolt is not coming out. Is there a load on the lower control arm?!? The arm needs to be hanging free. And post a pic of what you're looking at. I cannot imagine that bolt being that hard to remove.
Old May 20, 2010 | 05:13 PM
mhockey9090's Avatar
Some Wd will help losen it up. and like stove top said punch it out
Old May 21, 2010 | 01:43 AM
theres no load on it its just hangin there i dunno y its so hard eather i got one out about an inch. i think tomorrow im gonna get an air hammer on it.
Old May 21, 2010 | 12:44 PM
mav015's Avatar
use heat torch it for a little while and then hit it with a big ol hammer itll come
Old May 21, 2010 | 01:08 PM
use a pry big bar to put some continuous pressure up or down on the knuckle, which ever way it needs to go, then slam it with the hammer
Old Jul 24, 2010 | 05:36 PM
FullerF-150's Avatar
yeah so i've been attempting to remove these 2 bolts for about 4 hours now and still no luck. I was able to turn one almost out but it has got to the point that i can no longer turn it with a breaker bar. so i started hitting it with a punch and sledge, but still no luck. is there any danger if i keep hitting it? like will the rubber bushing be destroyed? and can i replace those rubber bushings if i do destroy them without buying a hole new lca?
Old Jul 24, 2010 | 07:30 PM
Monroetaco's Avatar
I had one that I worked on for 6 hours trying to get it out. Tried everything mentioned above, and it just would not come out. I ended up using a repo saw and cutting the bolt between the arm and frame member. Even after removing the LCA, the bolt would not come out. I even drilled the center out, soaked in everything including Kroil,tried heat, putting it in the freezer, BFH, BF pipe wrench, etc. After wrestling with it for 2 full days, I went a bought a new LCA.
Old Jul 24, 2010 | 08:45 PM
yea thats what i ended up doin i went through 2 diamond grit sawzall blades then bought two used lca's on ebay cuz i could get the bolts out. i tried to press them out with my shop press but just ended up busting my arbors.
