Sponsored by: CARiD
Replacing Inner Tie Rods, Help
Old May 4, 2010 | 05:25 PM
MUD DIGGER's Avatar
Has anyone Replaced their inner tie rods on 2004-2005 F 150, if so how long did it take you and what am i up against, is there anything i have to take apart to get to them any help would be nice and if any one has pictures of how they did it that would be great. thanks
Old May 5, 2010 | 10:56 AM
MUD DIGGER's Avatar
wow no one has done this, thats hard to belieave no one has any suggestions
Old May 5, 2010 | 11:19 AM
FX4life's Avatar
I've done it and it wasn't terrible easy. There is a special tool for it if I recall correctly.
Old May 5, 2010 | 01:06 PM
MUD DIGGER's Avatar
How long did it take you, also do you remember what tool it is my new tie rods come in tomorrow and i was hoping to tackle this, this weekend so if you remember what tool it is i'll go out and buy it today so i am ready cause i dont really want to rip apart my front end and then find out i dont have the right tool plus i dont even know what the tool looks like if you could get back to me on this i would appreciate it
Old May 5, 2010 | 01:44 PM
StoveTop's Avatar
Hmmm, I've done lots of outers, but inners?!? Never...on any vehicle.
Looking at a picture, it looks to have a threaded end but other than wrenching it, I have no idea. Plus I'd suggest replacing the outers too while you have it all apart.
Post pics and document your install as you have me curious as to how to replace the inners.
Good luck.
Old May 5, 2010 | 02:05 PM
gearhead5225's Avatar
There cake. Disconnect the outer tie rod, then pull the boot off your rack, the if you look there will be a bolt running from the inner into the rack. just use a regular wrench and and break it loose and it should just twist right off. The special tool is for the ones that are stubborn and don't wanna twist off. i work for a suspension shop and dont have the tool, ive always gotten away with just a normal wrench. and if you wanna get the special tool its only like 50 bucks...
Old May 6, 2010 | 03:49 PM
MUD DIGGER's Avatar
Thanks man you gave me a peace of mind by saying they are "cake" so i'm gonna go forth with it with out any hesitation, but no one has any idea how long this should take i have a good jack and air tools and bascially all the tools i will need for this so does anyone know how long it should take i am replaceing both of them both inner tie rods
Old May 6, 2010 | 05:09 PM
Ummm i can have both inners done on average in about 20 minutes on a bad day...they dont take long at all. Just when you take the boot off there might be a plastic cover over where you need to put your wrench on, just make sure you either count your turns or measure your outer tie rods so your alignment is close then get it to the alighment shop quickly.
Old May 6, 2010 | 05:48 PM
StoveTop's Avatar
Wow, that's really good info...I never knew that.
And glad you recommended measuring the tie rod before taking it apart. For guys who don't have a lot of experience, measure several times from a point to the outter rod end, and since the OP is doing inners too, measure to the inner end as well. Install your ends and match up to your measurements. It'll make your drive to the alignment shop a whole lot less scary!
Old May 6, 2010 | 06:57 PM
And glad you recommended measuring the tie rod before taking it apart. For guys who don't have a lot of experience, measure several times from a point to the outter rod end, and since the OP is doing inners too, measure to the inner end as well. Install your ends and match up to your measurements. It'll make your drive to the alignment shop a whole lot less scary![/QUOTE]
Not only will it make your trip less scary, it wont chew you tires up to.
Old May 6, 2010 | 07:14 PM
alex7191's Avatar
I replaced one. It was pretty easy. I had to use a Pitman arm puller to get it out. for sure have autozone or where ever loan you one. I wouldnt of been able to do it without one because there isnt room in there to break it loose with a hammer
Old May 7, 2010 | 07:16 AM
Your truck is older so you have a centerlink set up...his is new and has a rack n pinion so there is no need for a pitman arm puller.
Old Aug 7, 2011 | 09:51 PM
hicknick514's Avatar
where did you get the inners? i can't find them
Old Dec 30, 2011 | 03:35 PM
daparrothead's Avatar
So what size is the wrench needed for the inner tie rods? I need to do the inner on the drivers side of my 06 F150 5.4 4X4.
Old Dec 30, 2011 | 09:52 PM
Nobody? Come on, I'm planning on doing this tomorrow and having the correct wrench would be nice.
