Sponsored by: CARiD
Looking at lift kits, help me out!
Old Apr 20, 2010 | 06:12 PM
Fifty150's Avatar
Originally Posted by Kawasaki268F
Ok, so I have an 07 F150 V6 2WD, looking at 4-6" lift kits...is it possible to get a lift for under 2 grand?? Any suggestions on lift kits? What should I look for in a lift kit?
Yes. Yes you can. You can get a Fabtech 6” PERFORMANCE SYSTEM W/ DIRT LOGIC 2.5 COILOVERS for $1,974.13.
I also have an '07 2WD. I picked up the Fabtech 6" Performance Crossmember System w/ Dirt Logic 2.5 Coilover. I don't own this place or work there. Just wanted to share my research. I see a lot of people posting, asking for prices. I can't figure out how anyone on here is computer savvy enough to find & post on this forum, but does not know how to "Google".
I didn't buy my lift online. My local 4wheelparts.com store matched the price and sweetened up the deal with discounts on the installation & alignment, mounting & balancing, and re-gear - none of which I could have gotten through the mail. I know that there is a lot of bashing of 4wheelparts.com. Some of it rightfully deserved. However, my local outlet seems on the up & up.
Here it is. The best online prices I've found.
2004-05 F150 2WD 6” BASIC CROSSMEMBER SYSTEM
Using our arched lower control arm crossmembers and cast extended length spindle technology this system provides superior ground clearance with a smooth ride. Included in this system are 2.25” monotube front shocks that utilize the stock coil springs with anodized billet coil seats for a compliant on and offroad ride. Other features include lower control arm eccentric cams for easy alignment, sway bar drop brackets, 2” double pin cast iron rear lift blocks and u bolts.
6” Basic Crossmember System 2WD
Use 315/70R17 tire w/ 17x8 wheels w/ 5" BS w/ minor trim
1 K2000 Kit Reference Number w/Performance Rear Shocks
1 FTS22013BK Component Box 1
1 FTS22014BK Component Box 2
2 FTS7333 Performance Rear Shocks
K2000Our Price: $1,446.50
A. Dirt Logic 2.5 Coilovers
B. Reduced Offset Steering Knuckles
C. High Arched Lower Control Arm Crossmember
D. Differential Skid Plate
E. Alignment Cam System
F. Extended Sway Bar Brackets
G. Crossmember Impact Struts
H. Optional Steering Stabilizer
2004-2005 0-3” Dirt Logic 2.5 Coilover System 2WD Ford F150
Built for the offroad enthusiast, this coilover system features a 2.50” O.D. take-a-part shock with a height adjustability coming from a threaded body and Performance Coil Spring to achieve 0 to 3 inches of lift. Off road dampening capacity is so superior with this coilover we caution to not drive past the limits of the stock components of the vehicle.
6" Performance Crossmember System w/ Dirt Logic 2.5 Coilover 2WD
Use 315/70R17 tire w/ 17x8 wheels w/ 5" BS w/minor trim
1 K2001 Kit Reference Number w/Performance Rear Shocks
1 FTS22040BK Component Box 2
1 FTS22042 6" Dirt Logic 2.5 Coilovers Only
K2001Our Price: $1,974.13
Old Apr 20, 2010 | 06:17 PM
Fifty150's Avatar
Original Post
Old Apr 20, 2010 | 07:04 PM
Kawasaki268F's Avatar
thanks a lot...just dont think i can do the blue parts would totally ruin my black and white theme...probably going to stick to procomp
