Sponsored by: CARiD
Fabtech 6" Lifts
Old Oct 25, 2008 | 05:13 AM
Fifty150's Avatar
Fabtech 6" Lifts
I don't own this place or work there. Just wanted to share my research. I see a lot of people posting, asking for prices. I can't figure out how anyone on here is computer savvy enough to find & post on this forum, but does not know how to "Google".
I didn't buy my lift online. My local 4wheelparts.com store matched the price and sweetened up the deal with discounts on the installation & alignment, mounting & balancing, and re-gear - none of which I could have gotten through the mail. I know that there is a lot of bashing of 4wheelparts.com. Some of it rightfully deserved. However, my local outlet seems on the up & up.
Here it is. The best online prices I've found.
6" 4WD 2004-07 F150 PERFORMANCE SYSTEM
A. Extended length front shock utilizes stock coil springs
B. Reduced Offset Steering Knuckles
C. High Arched Lower Control Arm Crossmember
D. Differential Skid Plate
E. Alignment Cam System
F. Extended Sway Bar Brackets
G. Crossmember Impact Struts
H. Optional Steering Stabilizer
1 K2002 Kit Reference Number w/ Performance Rear Shocks
1 FTS22016BK Component Box 1
1 FTS22017BK Component Box 2
1 FTS22018BK Component Box 3
2 FTS7266 Performance Rear Shocks
K2002 Our Price: $1,692.73
6” PERFORMANCE SYSTEM W/ DIRT LOGIC 2.5 COILOVERS
As an upgrade to our 6” Performance System we offer the system with our Dirt Logic 2.5 adjustable Coilovers. The Dirt Logic 2.5 Coilovers feature a large 2.50” OD nickel plated steel body, 2.25” OD piston along with billet aluminum end caps, in a take apart design for fine tuning if required. This large front Coilover provides outstanding offroad dampening for aggressive driving while providing a compliant highway ride. Due to the superior dampening capacity of the Dirt Logic 2.5 we caution drivers not to drive past the limits of the stock components of the vehicle.
Use 315/70R17 tires w/ 17x8 wheels w/5" BS w/ minor trimming
Use 325/65R18 tires w/ 18x9 wheels w/5" BS w/ minor trimming
1 K2003 Kit Reference Number w/Performance Rear Shocks
1 FTS22021BK Dirt Logic 2.5 Component Box
K2003 Our Price: $2,307.98
2004-05 F150 2WD 6” BASIC CROSSMEMBER SYSTEM
Using our arched lower control arm crossmembers and cast extended length spindle technology this system provides superior ground clearance with a smooth ride. Included in this system are 2.25” monotube front shocks that utilize the stock coil springs with anodized billet coil seats for a compliant on and offroad ride. Other features include lower control arm eccentric cams for easy alignment, sway bar drop brackets, 2” double pin cast iron rear lift blocks and u bolts.
6” Basic Crossmember System 2WD
Use 315/70R17 tire w/ 17x8 wheels w/ 5" BS w/ minor trim
1 K2000 Kit Reference Number w/Performance Rear Shocks
1 FTS22013BK Component Box 1
1 FTS22014BK Component Box 2
2 FTS7333 Performance Rear Shocks
K2000 Our Price: $1,337.33
A. Dirt Logic 2.5 Coilovers
6" Performance Crossmember System w/ Dirt Logic 2.5 Coilover 2WD
Use 315/70R17 tire w/ 17x8 wheels w/ 5" BS w/minor trim
1 K2001 Kit Reference Number w/Performance Rear Shocks
1 FTS22040BK Component Box 2
1 FTS22042 6" Dirt Logic 2.5 Coilovers Only
K2001 Our Price: $1,825.14
Old Nov 11, 2008 | 11:49 PM
jrbhc8's Avatar
Is this place legitimate? That fabtech price is awesome!!
Old Nov 12, 2008 | 08:24 PM
travis08's Avatar
i found better prices than this and they are legit but a company price matched them for me.
shop here they have even lower prices
http://www.offroadtoystore.com/Merchant2/merchant.mvc?
Old Nov 12, 2008 | 10:31 PM
jrbhc8's Avatar
Thanks!! I looked on the website but couldn't find anything for 04-08 4wd F150's. Can you link me to them?
Old Nov 13, 2008 | 02:37 AM
travis08's Avatar
sorry bro idk anything about the 4wd i have a 2wd so i didnt even look at the 4wd parts im sure if u called them they could giv u a price i bet
Old Apr 20, 2010 | 06:22 PM
Fifty150's Avatar
The prices may not be current, but I just saw a recent post asking about 6" lift for '07 2WD. Instead of just telling the guy to use his search button, I figured I would drag this back from the dead. All you've got to do is "Google" the part number you want, and look for the best current price.
Old Apr 16, 2011 | 03:20 PM
hardrock3742's Avatar
AHHHH a k2000 for only 1400!!!
