Sponsored by: CARiD
ASAP HELP NEEDed!!
Old Aug 7, 2009 | 03:13 AM
nlegler's Avatar
ASAP HELP NEEDed!!
GUYS NEED HELP ASAP!!!! passenger side done perfect. okay driver side BIG ISSUE.. the upper ball joint will not tighten it only spins. i have tried prying down while trying to tighten it so it would catch and it wont and i cant think of anything to do will some one please help! im suppose to go in tmw to get new tires/rims/ and alignment done and this is the only thing stopping me!
Old Aug 7, 2009 | 08:03 AM
DYNOTECH's Avatar
First make sure the nut is not crossthreading. You should be able to thread the nut on by hand most of the way. Are the treads messed up and/or do they go far enough up the shaft to allow the nut to completely tighten ? Clean any grease off the male and female. Take a brass hammer and tap down on the ball while tightening. Try using an impact gun on the nut instead of a wrench or socket. Are you sure its the correct ball joint? Some have different size shafts for different makes of cars, is the shaft fitting snug when pressed into the female control arm? May be a defective ball joint, compare it with the one you removed,check thread depth, length, diameter of the taper etc. Good luck
Old Aug 7, 2009 | 12:08 PM
nlegler's Avatar
If you guys could go to my profile and go to the help called hell bent install there are pictures of what my problem is and any adivice to get that fixed would be great... Its the only thing i have left to do and then it will be done!!
Old Aug 7, 2009 | 12:18 PM
mdhawkin's Avatar
Looks like your UCA will not go down any farther. In order to tighten that ball joint it is having to lift the lower assembly and its takes too much to do that so the ball joint just spins. I think what you need to do is use your jack to help lift your lower assembly. If that does not work can you put the tire back on, let the truck down then tighten the nut on the ball joint. By doing this you should shift the upper assembly (top of the spindle) closer to the UCA and it will not have to come down so far.
Old Aug 7, 2009 | 12:26 PM
ab46501's Avatar
X2, I just said this exact same thing in your other thread.
Old Aug 8, 2009 | 12:06 AM
nlegler's Avatar
First want to thank everybody that has helped me out with the whole ordeal!! Well got it finally done and installed!!! seems though the front sits higher now then the rear so first question is will it settle after a while?? 2nd question so i took it out for a lil test drive and now i'm having steering problems. first it is easy to turn left really really easy almost to easy but its hard to turn to the right and then when driving at minimal speeds like 20 mph it pulls hard to the left. since it is going in for realignment on monday (not getting driven all weekend, just the 30 mile trip down to the auto place) will the realignment fix this problem? and should i tell the mechanic about all of this and maybe have him take it out for a short drive to see what he thinks?
Old Aug 9, 2009 | 09:31 AM
nlegler's Avatar
btt
Old Aug 9, 2009 | 09:56 AM
mhockey9090's Avatar
Your alignment should help the pulling to the left and if it doesn you may want to check your tie rods. Have the shop check all that out when you take it in
