How can i give a 2wd a "lifted" look
Alright guys, well, I am pretty new to these forums, I've been scoping them out for a while though. Just got around to making an account.
I have a 2008 F150 STX, 2wd, sadly. Everything is stock, and I am after a good lift/tire/wheel combo that will give my truck a nice lifted look.
I'm gonna start it off by saying that a 6" lift is way out of my price range. I would like some sort of combination involving a body lift, leveling kit, AAL or something along the lines of that.
As for the tires and wheels, I would like to get some 33/12.50/20, maybe 18's.
I am open for any suggestions involving different combinations, wheel/tire brands, and other things along the lines of this.
Thank you for your time in advance!
pic:
pic:
Add a 2.5 inch Autospring leveling kit and a lift block out back. If you want more lift, you can add a body lift. However, body lifts are a pain to install on the 04-08 trucks. If you have to pay someone to do the installations, you will have about the same amount of money invested in a standard 6 inch Pro Comp lift. A leveling kit will allow you to fit 33's. Add the body lift and you can fit 35's.
idk if this help but here is a pic of my 2wd with 2.5 leveling kit and 33" hankook M/T..
its definitely not lifted but not stock.. works until I can get the fabtech lift kit
<a href="http://s574.photobucket.com/albums/ss185/rayc2681/?action=view¤t=P1040208rs.jpg" target="_blank"><img src="http://i574.photobucket.com/albums/ss185/rayc2681/P1040208rs.jpg" border="0" alt="Photobucket"></a>
<a href="http://s574.photobucket.com/albums/ss185/rayc2681/?action=view¤t=P1040207rs.jpg" target="_blank"><img src="http://i574.photobucket.com/albums/ss185/rayc2681/P1040207rs.jpg" border="0" alt="Photobucket"></a>
Munkey gives you a pretty good idea of what your looking at doing. If you do a 2.5 leveling kit thats what it does is levels it, gains you some room for larger tires up front as well.. but then if you add blocks in the rear or AALs..well your just gainin your rake back, the rear will be higher than the front again, Id say do a 2.5 level kit up front then get a 3 BL if you can afford it, it will give you the higher lifted look and sit level and run 33s
Question is, will the Bilsteins give enough lift/leveling in the front to allow for 33's on my 2WD?
