1.5" Lowering Shackles for a '05 2WD F-150?
I was wondering if anyone knew of 1.5" lowering shackles for the 04-08 F150s 2WD. I know the shackles I've seen advertise a 1.5" drop if it was a 4WD. I ordered Eibachs 35112.540 (2" coils & 3" leafs) kit yesterday and I still want to lower my truck atleast another 1" in the rear. I would like my truck to sit level and 1.5" shackles would be ideal. I think H&R make a set but not sure the quality and they seem to be the most expensive lowering shackles on the market. I like Ground Force's shackles, but does anyone know for sure they all come with 2 holes? All the GF shackles I see (91200) or (91201) all advertise a 2" drop not 1-2" drop, which 2" would be too much of a drop. Thanks in advance for anyones help with this.
I just got off the phone with GF. You were right, one hole is 2" and the second hole is 1.25"-1.5" which will be perfect. Ordering directly from them was almost as cheap as anywhere else. Except I had to pay for 3-day shipping since they are in PA and I'm in WA and I want to install everything at once. The guy talked me into the 91200 kit over the 91201 kit saying that the OEM bushings will wear faster. He said to grease everything with a marine grade grease or wheel bearing grease and I shouldn't have any squeaky issues. Thanks again!
I've heard nothing but good things about GF and when I ordered directly from them, they were only $105 plus shipping. Standard UPS ground is $15 but I paid $37 for 3-day UPS. Which ones 91200 or 91201 are you going with? It sounded like 91200 are better if the are greased properly. But I have heard otherwise.
Yeah I was goin for the 91200, but then I heard the 91201s where better, shoot It dont really matter to me I suppose.. I may go through them and get them as well, I didnt think about that, I was goin to get them from summit, I think they are like $108 there, It will come down to the cost of shippin b/c I could drive to summit from my house and save the shippin if they have them in stock. Sounds great though let me know how it works or turns out, you'll probably get yours in and on before I get to it.. you plan on puttin the shims in there as well when you do the shackles or just doin the shackles and waiting to see if you need to install the shims..? Ive heard to do them while your already working on it and Ive also heard no need to do them..
Sounds good, I may have to go that route after doin just the 2 inch drop shackles.. yeah the shackles shouldnt be an issue or to long puttin on, it will run me a little more time though if I put in them shims.. Well see how it goes.. I may make a run to Summit tomorrow, and try to get them installed this weekend.
