Sponsored by: CARiD
Going Under the Knife!
Old Sep 22, 2009 | 05:35 PM
  #226
blackedoutV6's Avatar
dang, looks like youll have to get some with a different offset then..
and i just noticed this site filters the word t i t s
Old Sep 22, 2009 | 05:47 PM
  #227
1fast4.6's Avatar
having a hard time finding some wheels with lots of positive offset
Old Sep 22, 2009 | 05:50 PM
  #228
could you just put a narrower tire on it?
you want less offset more backspacing
Old Sep 22, 2009 | 06:11 PM
  #229
1fast4.6's Avatar
Well after scratching my head for a while. Im really doubting that i will find rims to fit. The front i can cut the lower and upper control arm to shorten them. That will bring the tire in. For the rear ill just have to shorten the axle. This route will be lots cheaper than droping a couple grand for wheels and tires.
But i was looking forward to getting some new 22's
Old Sep 22, 2009 | 07:42 PM
  #230
06lariat4x4's Avatar
dude this sounds like a rally exhausting project hehe. but like everyone i think its worth it to make a custom truck that only you will have
Old Sep 23, 2009 | 01:32 PM
  #231
1fast4.6's Avatar
2 new Axle's from Moser's should be gettin made soon. Also found out my spider gears are a little messed up
***** it.. run it till she blows!
Old Sep 23, 2009 | 02:52 PM
  #232
I'd replace the spiders, you dont want to chew up those new custom axles and have to order new ones again.
any chance you can mill some off the back of the wheels?
how much is it rubbing? and is it rubbing at "normal ride height" too or just layed out?
Old Sep 23, 2009 | 03:55 PM
  #233
1fast4.6's Avatar
ive already looked at the wheels and there isnt enough there to make it work. The front rubs with the tire tucked about 1 inch. the rear rubs on the fiberglass lip untill the top of the tire hits the fender. I believe that the front A Arms are longer than stock. thus pushing the tire out.
Old Sep 23, 2009 | 04:27 PM
  #234
yah did you roll the fender lip up front?
Old Sep 23, 2009 | 04:47 PM
  #235
1fast4.6's Avatar
Just a tad. basically where the tabs are for the plastic inner fender to mount to. I have got the front tires to clear now. Not by much! Now i just gotta start cutting the fenders out. Looks like there wont be much left when im done.
Old Sep 23, 2009 | 04:51 PM
  #236
Veteran: Army
you ought to run zoomies up thru the hood for your exhaust
Old Sep 23, 2009 | 05:06 PM
  #237
IH8ATTN's Avatar
i suggest get new wheels...as for your air managment setup i suggest you run a belt driven compressor or scuba tanks, I did both as I was trigger happy all the time and those itty bitty compressors don't fill 16 gal of air to 200 psi so fast
Old Sep 23, 2009 | 05:43 PM
  #238
1fast4.6's Avatar
Well done workin on her for the night. Im kinda torn though. The inner fender support is very hard to get to with my little 4 inch cutoff wheel. I can get to the other side of it but my wheel is too close to the outer fender for comfort. I might have to take the fenders off.
Old Sep 23, 2009 | 10:51 PM
  #239
bagtodrag's Avatar
great project, its coming along pretty good. Another alternative to what you could have done with your front suspension is this...it it also what I have done on mine.
Raise your upper arm mounts atleast 2", and swap your uppers left to right and right to left to help with firewall clearance and you only have to tap it with a hammer a few times (assuming you will only be laying frame, if you bodydrop it down the line you will ofcouse have to tub your firewall), flip your lower balljoints and replace them with Chrysler Cordoba balljoints, flip your tie rod ends, cut off your spring purch and use a customs bracket with gussets, youd have to use a reamer to ream out the other ends of your spindles to accomidate the flipping of the lower joint and the rod ends. Just an option of you wanted to save money and not go with spindles.
Old Sep 24, 2009 | 09:54 PM
  #240
1fast4.6's Avatar
Yeah with how im doing it im going to have to cut into the firewall quite a bit. even have to relocate the computer
