Sponsored by: CARiD
pics of my new lifted 03 f150!!!
Old Jan 23, 2009 | 09:23 AM
  #31
d4life45's Avatar
cool thanks! I will look into that. any input on adding leafs or rear blocks?
Old Jan 23, 2009 | 09:33 AM
  #32
d4life45's Avatar
if i go with rear blocks i would just be stacking them on top of the ones i already have correct? would i need to get new u bolts and the screws or would they use the same ones? the same with the AAL they would be stackin on my current ones correct?
Old Jan 23, 2009 | 11:24 AM
  #33
d4life45's Avatar
bump
Old Jan 23, 2009 | 11:41 AM
  #34
minimonster17's Avatar
do us all a favor, and stop w/ the bumps every other hour. some of us have work, school, etc. sorry to sound like a ****...
anyway, to answer your question, i don't really like stacking blocks. if possible, try to get like a 5.5'' block. new, lift leaf spring packs are expensive, and may not be within your budget.
however, whatever you do w/ your blocks, yes, you will need longer u-bolts to compensate for the added block height. search locally. a local shop should be able to bend new ones for you the length you need.
the AAL will work w/ your stock leaf springs, correct.
personally, on my setup, i am running a 6'' fabtech, and 3'' body lift on 35's. i am running no blocks in the back, and am using atlas leaf springs for my 6'' rear lift.
if you offroad, you're really not gonna like having that much block, as ***** already noted...
Old Jan 23, 2009 | 01:42 PM
  #35
ModBargains's Avatar
Looks good. Deffinately look into 37" tires when its time to upgade.
Old Jan 24, 2009 | 01:51 PM
  #36
Veteran: Army
I wouldn't stack blocks and I would try not to run blocks at all, just for a larger lift rear spring
Old Jan 24, 2009 | 02:33 PM
  #37
F150NFdriver's Avatar
coil spacers? i thought all 97-03 had torsion bars? correct me if im wrong
Old Jan 24, 2009 | 03:16 PM
  #38
wandell's Avatar
Only the 97-03 4x4's use torsion bars. The 4x2's have coilsprings.
Old Jan 24, 2009 | 10:00 PM
  #39
wxscpo's Avatar
Originally Posted by f150 rider
Nice truck man! I agree with everyone else some paint on that frame would make a world of difference in the looks
Add me to the list as well. Also would consider painting that bottom rocker panel as well. Truck does look good though.
Old Jan 25, 2009 | 12:48 AM
  #40
d4life45's Avatar
Alright thanks alot! I will look into painting the frame. how much do you think it will run me?
Old Jan 25, 2009 | 12:53 AM
  #41
dexx00420's Avatar
Originally Posted by Shepard69
Good for you. Now go post them in the Aftermarket - suspension forum. Not the OEM forum. I'm Lifted too, I wan to see more stuff in the aftermarket forum so quit posting in the OEM forum.
What are you the forum ****? You're not a mod so don't try and do their job. A bunch of other threads show you bitching about the post location; give people a break and grow up a little bit.
Anyway,
Truck looks good bro.
Old Jan 25, 2009 | 01:37 AM
  #42
hahah ok didnt even notice it was a 2wd
Old Jan 25, 2009 | 01:41 AM
  #43
4.2trimble's Avatar
lol hard to tell the way its set up.
JUST DONT LET IT HAPPEN AGAIN
lol i really think this truck will look sick on 37's
Old Jan 25, 2009 | 01:56 AM
  #44
d4life45's Avatar
Thanks for the feedback!
Old Jan 25, 2009 | 03:12 AM
  #45
f150offroader's Avatar
Originally Posted by 4.2trimble
looks great man. when those 35's wear out slap a set of 37's on there.
I second that. They look too small with that big of lift.
