pics of my new lifted 03 f150!!!
would this work on my truck. fabtech add a leaf kit 1.5 inch heres the link http://www.4wheelparts.com/Lift-Kits...t_pn=FABFTS214
and the daystar comfortride suspension coil spring spacer kit 1.5 inch heres the link http://www.4wheelparts.com/Lift-Kits...n=DAYKF09105BK
would that make it even? the front wont be higher then the back or likewise.
sorry for so many questions but this should give me about like a 12 inch lift total right? would it be better to add rear blocks instead of leafs? again sorry for so many questions and thanks for your help!
i have fabtech 6" suspension with torsion bars cranked to be about a total of 8" of lift and i am running 38s...the rub a little bit on the fenders so im thinking about adding a body lift but it wouldnt be necisary for street driving. it only rubs when the from suspension "flexes" but normal driving it does fine. truck looks good though man. i have a 97 and love it. but i would definetly look into getting bigger tires. IMO i like it when the fenders are filled with tire...not so much of a gap. but my opinion
you can check out my truck in my gallery and see what mine looks like with 38s.
and as for the back, i have 2" add a leaf and a 5" block. i really dont like my blocks cause it moves the axle around but it is definetly the cheapest and easiest way to do it. i am currently doing some research on doing a sort of shackle flip instead of getting springs cause those cost SO much.
you can check out my truck in my gallery and see what mine looks like with 38s.and as for the back, i have 2" add a leaf and a 5" block. i really dont like my blocks cause it moves the axle around but it is definetly the cheapest and easiest way to do it. i am currently doing some research on doing a sort of shackle flip instead of getting springs cause those cost SO much.
