Sponsored by: CARiD
leveling out need help
Old Jan 4, 2009 | 03:49 AM
Fordtruckman88's Avatar
hey guys,
I have a stock 2005 ford f150 xl no suspension mods and well i want to level the front end till it it level with the rear, so my question is what size of leveling kit do i need? 1in 2in 2 1/2 in? and whats a good brand to go though
Old Jan 4, 2009 | 07:36 AM
mavrik2747's Avatar
I'm looking to do the same for my 05 screw fx4. i was thinking 2.5" but not sure...also I will be putting 33's on and I'm positive they'll fit as I've seen alot of pictures on here with people riding on 35's.
Old Jan 4, 2009 | 08:54 AM
wandell's Avatar
Most members say a 2.5 inch kit will level a 4x4 while a 2 inch kit wil level a 4x2.
I'm sure every truck is a little different so you may need to just measure your truck to see how much lift you need up front to level it.
Old Jan 4, 2009 | 09:01 AM
cincyfordman's Avatar
I went with a 3inch leveling kit from Hell Bent Steel and also doing a 1/1/2 add a leaf in the rear
Old Jan 4, 2009 | 09:06 AM
Barrett's Avatar
Easiest way to find out what size leveling kit is to walk out to your truck and measure the distance between the wheel well and your tire. Subtract the front tires by the back and thats how big of a leveling kit you will need to make it sit level.
I am going to buying a 2.5" leveling kit from Autospring today for my 2005 supercrew 4x2. You can buy them directly from Autospring via Ebay with free shipping.
Old Jan 4, 2009 | 09:22 AM
Buke04Screw's Avatar
I just put on a 2.5" from Auto Spring on Friday. The 305/65 R18 BFG AT's will be here and mounted(hopefully) Wendsday.
Old Jan 4, 2009 | 09:29 AM
Barrett's Avatar
Well Welcome to the site! Make sure to post pictures when you can!
Old Jan 4, 2009 | 09:42 AM
Thank You, I've been here awhile (lurking) reading up on everything I could to make the choices I've made for these first Mod's. I was going to wait until everything was finished to post pics, but will try to post what I have later.
Old Jan 4, 2009 | 09:57 AM
last5oh_302's Avatar
From what I've seen, the 2.5" kist raises the front a tad higher than the back on a 4x4. Then you end up needing blocks or add a leafs to level it out again.
I have Bilstein leveling shocks/struts enroute. I'll be installing them at the 2 inch setting, which will hopefully be perfect.
Old Jan 4, 2009 | 10:16 AM
brianjwilson's Avatar
I have a set of FX4 shocks in the garage now. I know some 2wd trucks have installed FX4 shocks and it gives them a couple inches in the front, due to the way the coil sits on them. Might be worth researching that too.
Otherwise, you can get bilstein 5100's adjustable to stock height, +1" or +2".
Or of course the autospring.
When you measure your truck, keep in mind that the front wheel well is larger and higher. Most people want the wheel wells level, and if you measure the lines on the body, the rear is still about an inch higher that way. I prefer a little forward rake still so I'll probably add a 1" add-a-leaf with my leveling shocks.
Old Jan 4, 2009 | 10:37 AM
BlkButy's Avatar
I have a 2008 XLT Screw - See SIG.
I went with the AS 2" and my truck is level.
Old Jan 4, 2009 | 02:46 PM
Nemisus's Avatar
here is my 06 Screw XLT... I went with the Bilstein kit with matched rear shocks! Couldn't be happier with this set up!
This is with 35" tires! There is minor rubbing at full wheel lock!
If you do NOT ever plan to go higher than just leveling... I recommend you get 33's! I did 35's because I intend to get a full 6" suspension some time in the near future!
Hope this helps
Cheers
Nemi
Old Jan 4, 2009 | 03:13 PM
lanemeyer's Avatar
My 2004 4x4 took a 2in lift to level it, Some take 2.5 to level. I took the floor jack out and jacked it up in the garage to see what lift I needed.
Old Jan 4, 2009 | 05:49 PM
Heres my 2004 Screw 4X4
Before
After 2.5" Auto Spring
Old Jan 4, 2009 | 05:51 PM
I know the date and time is off
