Sponsored by: CARiD
vibration since lift
Old Dec 10, 2008 | 10:41 PM
  #31
fx4 for life 79's Avatar
hey keep an eye on your alignment cause mine is f'd up and you have them expensive toyos
Old Dec 11, 2008 | 01:58 PM
  #32
04 kbgt's Avatar
true true, i am going to try to find a better place, NY has nothing that caters to the aftermarket at all its horrible, i cant wait to be able to move out to the west coast
Old Dec 14, 2008 | 06:01 PM
  #33
Shepard69's Avatar
So here you go. Pics with the spacer I just put in today.
PS I'll redo the seal next week.
Old Dec 14, 2008 | 06:04 PM
  #34
Shepard69's Avatar
Also for those of you running 2 spacers on the 6" lift. Go get your springs re-arched and have a leaf professionally installed. It will look like this. ( Mine sits 3/4" higher in the rear - Also I'm running the stock tires for the winter)
Old Dec 14, 2008 | 06:17 PM
  #35
Shepard69's Avatar
Originally Posted by fx4 for life 79
hey 04 kbgt i went by discount and my tires are wearing unevenly so i think it might be alignment
Did you check to feel if your yolk had play? It doesn't take long to wear out the slip yolk with the vibration of the shorter drive shaft. Mine has some play. I will likely have to get a new yolk. Should have put the spacer in right after I did the lift. Oh well.
Old Dec 15, 2008 | 08:16 PM
  #36
i think it might, but i put my new tires on and got it aligned and it rides a lot better. there is no shake in the steering wheel and it seems to ride a lot smoother
Old Jan 4, 2009 | 12:17 AM
  #37
82chester's Avatar
where are you guys purchasing your shims? thanks
Old Jan 5, 2009 | 04:02 PM
  #38
Slimline's Avatar
I had the same issues when I lifted my truck. I had a machine shop lengthen my driveshaft 2 1/4" for $135.00, including balancing. I still had the vibration but not near as bad, after buying an electronic level I found my driveshaft/pinion angles were way out of wack. Shimming it solved all my vibration issues. I bought my shims from a suspension specialist, they were about 25 bucks.
