Sponsored by: CARiD
Help with tire size!?
Old Oct 31, 2008 | 09:14 PM
Westcoast4121's Avatar
Need help with what tire size I need. I have a 2002 F150 crew cab 2WD and I am going to buy a 7.5" lift for it. What tires can I run if I have the 7.5" lift and a leveling kit? I want something bigger than 35" tires, but dont want to buy a body lift right now. Thanks
Old Oct 31, 2008 | 11:47 PM
cH1rO420's Avatar
Are you serious.. Drop that truck!!!
Old Nov 1, 2008 | 06:54 AM
Fifty150's Avatar
35"
Old Nov 1, 2008 | 10:56 AM
wandell's Avatar
Personally, I'd stick with 35's. If you use an 8 inch wide wheel youmay be able to squeeze 37x12.50's on there but it will be really tight.
Old Nov 1, 2008 | 02:45 PM
06yz250f's Avatar
stick with 35's. remember your roughly 2" lower than a 4x4. so your getting 5.5" of lift over a 4x4 so a 35 should be perfect for that lift. what wheels are you going to be running? if you do decide you want 37's (will require re-gearing) you could get coil spacers and come close to running 37's w/out a problem with the right wheel
Old Nov 1, 2008 | 03:47 PM
4.2trimble's Avatar
guys dont forget about 36's
im sure you can just do the 7.5" lift and coil spring spacers and clear 36's fairly easily
Old Nov 1, 2008 | 04:10 PM
06yz250f's Avatar
x2.
Old Nov 2, 2008 | 08:12 PM
Thanks. I am running the rims I have on it. I can get 36" tires with coil spacers?
Old Nov 2, 2008 | 08:40 PM
Fifty150's Avatar
Good luck with finding a kit that allows for OEM wheels. You do not want to order a kit, install the kit, mount the tires on your wheels; only to find out that it won't work.
Old Nov 2, 2008 | 08:43 PM
I don't have the stocks anymore. I bought 20" rims acouple of weeks ago.
Old Nov 2, 2008 | 08:44 PM
4.2trimble's Avatar
he doesnt havce OEM wheels....
OP if you wanna TRY to run 36's then you will need the 7.5" Fabtech + Coil Spring spacers.
what size are those wheels? Id check out Super Swamper Iroks for some 36's i think they make 36's for 20's
Old Nov 2, 2008 | 08:53 PM
Fifty150's Avatar
The backspacing on the aftermarket wheels still need to be within the lift kit manufacturer's specs.
Old Nov 2, 2008 | 09:06 PM
4.2trimble's Avatar
but yet they still arent OEM...
he will soon find out if the wheels will work or not.
but fifty150 has a good point:
but anyway what is the Backspacing on those wheels?
Old Nov 2, 2008 | 09:10 PM
4.2trimble's Avatar
you will need 4" of backspacing for the Fabtech 7.5"
and im sure 4" for the spindle lift as well
Old Nov 2, 2008 | 10:45 PM
wandell's Avatar
Most off road styled wheels for 97-03 F-150's have 4.5 inches of bs, so I'm sure those will be fine.
