Sponsored by: CARiD
4x4 FX4 Coilovers installed on 2wd
Old Sep 29, 2008 | 01:19 AM
stic-o's Avatar
Talking 4x4 FX4 Coilovers installed on 2wd
I picked up some '07 4x4 FX4 coilovers for $50 with only about 20 miles on them. Guy bought the truck then went straight to 4WP.
So I put them on my 2wd instead of lift spacers
Before
After
Before
After
Old Sep 29, 2008 | 04:44 PM
starbiker99's Avatar
What headlights do you have? FX2? BTW looks good. Need to pick up a little bigger tire.
Old Dec 7, 2008 | 11:30 AM
f22a's Avatar
What parts exactly did you swap from the FX4? I want to do the same thing.
Old Dec 7, 2008 | 01:07 PM
RJcavF150's Avatar
nice!!! im planning on doing the same, plus a 2.5 inch spacer and an add-a-leaf in the rear!
Old Dec 7, 2008 | 05:44 PM
06yz250f's Avatar
are you 2wd?
if so you can't put 4x4 coilovers, a 2 1/2" spacer. there is no possible way. you can either do a 2 1/2" spacer or 4x4 coil overs
Old Dec 7, 2008 | 05:53 PM
dkgreyf150's Avatar
looks alot better
Old Dec 7, 2008 | 06:20 PM
BlkButy's Avatar
How much lift does that get ya by going with the 4x4 Coilovers? Looks like only 1" or so!
Old Dec 7, 2008 | 07:15 PM
pylda's Avatar
Originally Posted by 06yz250f
are you 2wd?
You can install the 4x4 struts and the level kit. No problem at all. There are a bunch of Fx4 guys on here that run a level kit. He is replacing his 2x4 struts with the 4x4 stuts. The coil is the exact same.
Old Dec 7, 2008 | 07:33 PM
mattd17's Avatar
i would think that would put the balljoints at a pretty bad angle. all and all your looking at like 4"-5" of lift with the combo..... i believe thetallets leveling kit you can find is a 3", and even that puts the angles questionable.
Old Dec 7, 2008 | 07:42 PM
06yz250f's Avatar
ok but there is a difference between a 2x4 and an fx4. about 2" . so i will pay to see you get a 4x4 coilover and a 2 1/2" leveling kit to fit, work, and not destroy all the front end suspension parts. if that was even possible wouldn't you think people would do it to get 4 1/2" of lift?
Old Dec 7, 2008 | 07:44 PM
RJcavF150's Avatar
how would it put it at anymore of an angle? 4Wd guys run leveling kits all the time.
Old Dec 7, 2008 | 07:55 PM
Paralyzer's Avatar
exactly....a leveling kit on a 4x4 adds about 2 or 2.5 inches of lift. adding 4x4 struts plus a leveling kit on a 2wd is like 4.5 inches....keep in mind a stock 4x4 and a stock 2wd do not have the same frame....
Old Dec 7, 2008 | 08:04 PM
06yz250f's Avatar
x2. if you wanna try and do that on your truck, go for it, but its not possible.
Old Dec 7, 2008 | 11:02 PM
pylda's Avatar
Im sorry, but you are wrong.
Old Dec 7, 2008 | 11:23 PM
Paralyzer's Avatar
ok buddy...
