Torsion bar removal
Torsion bar removal
I tried the search and none of the threads were resolved, and the topics so old that the old threads are now removed.
I bought a large claw puller and can't get the center bolt to reach the key pilot hole. I need another 3" to reach. It looks like a c-clamp would work if the bolt end fit in the pilot hole.
What am I missing here? Kind of running out of time.
a c clamp would work, however, before spending $ on tools, see if you can back the bolt out with just a wrench. i too bought a two claw puller, and turned out not needing it. after removing the adjuster bolts/nuts, unbolt all the hardware holding the torsion bar crossmember onto the frame. then, take an iron stake, hold it on the front of the bars (there is an access "hole" in the front of the lower control arm) and pound the stake with a sledge. this will make short work of the seemingly impossible task of getting the bars out. (yes, my bars were rusted in there pretty good too.
-Jon
)-Jon
-Jon
)-Jon
I use the gm torsion bar unloading tool to do the chevy, ford and dodges. Here's a link to one http://www.thepartsbin.com/cartools/...ng_tool-d.html Most of the local 4x4 shops will have them and rent them out. I rent them out for $20 with a $120 deposit just in case it doesn't come back.
Take the anvil off of a C clamp and use the ball end to fit in the key.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
-Jon
)-Jon
wonder how difficult installation will be.
well it worked! sort of. I used the clamp to defuse some of the tension and removed the nut so the lever can drop. had a hell of a time wackin the levers off. I ended up just keep the bars attached to the lower arm since I'm just pulling my tranny. Might need a proper clamp for assembly.
I bought a 4inch 2 claw gear puller and it worked perfectly on the torsion bar key. I still can't the bar out though. I'm gonna try releasing the crossmember and driving it out of the lower control arm so I can change the ball joints.
