Now I'm REALLY confused....torsion cranking????
I just got off the phone with a local alignment shop, and contrary to what I've read here, they tell me that the MAXIMUM lift I could get out of cranking the torsion bars on my 98 F150 would be 1/2". Is this true or did this guy smoke his breakfast?
Then he REALLY threw me for a loop! I asked him how much he'd charge to crank the TBs and realign it, and he said "Probably $49.99 plus tax....that is if you don't need the special camber shims. If you need those, just the shims will cost you $120."
Is this guy nuts, correct, or is he just trying to lift a few extra bucks off me?
An alignment will run you about $50 give or take, but I have never heard of anyone needing special camber shims. I've cranked them on 2 different vehicles, my old 2000 and my current 2003. I got about 2" of lift on each, never had any problems.
Personally, I would crank them and then go to a different shop and get an alignment. I'm not saying this guy is trying to rip you off, but I can promise you that I trust the word of this forum more than I do any mechanic.
Aha. Now how does one know when he's approaching the "over-cranked" stage? I'm assuming it's obvious? I'm also assuming this can only be done with the front jacked up...tires off the ground?
You know what's funny? I just spoke with 2 different "off road" shops, and both said I'd stand to gain 1-2", and I probably wouldn't need a realignment. Their prices to crank the TBs were just $30 too. The alignment shops all said I'd DEFINITELY need a realignment, I'd only get 1/2" maximum lift, and I'd possibly need a cam kit. One of the alignment shops even said the change gained from the cranking is only temporary?? The cheapest an alignment shop would crank the TBs for was $60, and if I needed the "cam kit" I'd have to add at least $50.
WOW! I'm just gonna do it myself...sink or swim. If it works, FANTASTIC! If not, I'm no worse off than I was.
I didn't jack the front up when I did mine, but they can be a little difficult to do. If you have a cheater bar you can put on the end of the rachet, it will help.
An alignment is highly recommended. Anytime you mess with your T-bars, you should get one.
As far as overcranking them goes, just do each side an equal # of times. Once you crawl under there, you'll see how much room you have to work with. 3 or 4 complete revoltions should get you about 1 1/2 -2" of lift. But again, make sure you are keeping an eye on things because every truck is different. I remember having to crank my 2000 more than my 2003 to achieve the same look.
I'm sure someone else will chime with some input also. But it's not really that big of a deal IMO. Good luck.
I just cranked mine a week or so ago and got about an 1 1/2" out of and it looks so good im not gonna use my leveling keys. I got under the truck, sprayed the bolts with some lube and used a nice long handle breaker bar and cranked em. Didnt even put a jack under it. An alignment would definitely be a good idea though after words. If thats not enough lift, you can always buy my torsion keys...
Sorry to rain on your parade, but torsion keys ARE NOT RECOMMENDED for use on these trucks. They are rekeyed to allow you to crank much higher than the stock keys, and thus, put too much strain on the front suspension. The highest I would go is as far as you could crank them w/ the stock keys. I have ran my truck for two years w/ the stock keys cranked fully up, and no issues. I will say that my cv angles are a little less than ideal though.
I lifted my front end when I did it, made it a lot easier. I did 3 full turns got about 1" out of it. I did need an alignment, I also needed shims ($65), cost me about $200 total. That was back in May 2003, never had any problems. Also remember to take a marker or crayon and mark the bolt head so you know where it started.
