Sponsored by: CARiD
Is this easy to do??
Old Aug 20, 2008 | 03:27 AM
RAF150's Avatar
My bottom leaf spring on my driver side rear leaf spring set up is off about 1 inch. What is the best way to get it back into place? Can I just jack up the rear axle, lossen the U-bolt and hit it back into alignment?
Also, what should I torque the U-bolt back to when i'm done?
thanks guys...
Old Aug 20, 2008 | 10:22 AM
_cashel's Avatar
try just hammering it back a few times, or jack it up and hammer it back. I remember having to do this to my older truck a year or so ago, and I don't think I un-did the u-bolts or anything.
Old Aug 20, 2008 | 10:24 AM
_cashel's Avatar
edit: even if you wanted to though, just undo the u-bolts do like you said. I'd torque em down till their good and tight with a breaker bar. I just completely dropped my rear axle to have a friend regear it, and the ubolts on there were damn tight, even with a breaker bar.
Old Aug 20, 2008 | 12:10 PM
RAF150's Avatar
Yea, I tried hammering it back with no luck. I'll go ahead and loosen it up to hammer it back into place.
appreciate the response
