Sponsored by: CARiD
pro comp lift
Old Apr 1, 2008 | 03:56 PM
ColonelBlue's Avatar
Question pro comp lift
anyone here running stock rims with 35s on the procomp 6 inch lift with a new body f150,or know of someone?
Old Apr 1, 2008 | 04:14 PM
Hash278's Avatar
According to Procomp you cant run the stock rims with their lift. Not sure if anyone is running that setup.
Old Apr 1, 2008 | 06:04 PM
2006jackedf150's Avatar
Iv seen people run the 6" pro comp with stock rims and bigger tires. looks sorta cheezy. I would think there would probably be some rubbing though. but your really better off to get a set of wheels and have it all work right. iv got a 2 year old set of 20" centerlines and 325/65r/20 bfg A/T, i think theres a pic in my gallery if your intrested. ill let them go really cheep.
https://www.f150online.com/galleries...cfm?gnum=11517
Old Apr 1, 2008 | 06:13 PM
fx4 for life 79's Avatar
it would be cool if u could
Old Apr 1, 2008 | 07:02 PM
clar's Avatar
my stock spare will fit in a emergency without rubbing
Old Apr 1, 2008 | 07:17 PM
whats the backspacing
Old Apr 1, 2008 | 07:23 PM
Helrazr's Avatar
Smile
I called Pro Comp and asked them. They said it was fine and there is no fitment issues?
Old Apr 1, 2008 | 09:26 PM
wandell's Avatar
I know I've seen members here with 04-08 Pro Comp lifts and oem wheels.
Old Apr 2, 2008 | 12:32 AM
Hash278's Avatar
I stand corrected.....I was misinformed
Old Apr 2, 2008 | 01:40 AM
cool i might go with the stage 2
Old Apr 2, 2008 | 05:54 PM
JD790's Avatar
It will work and it won't work at the same time.
Explanation: I tried this when I took a trip to Colorado. I have the factory 17" XLT wheels and tires. They bolt on fine, the go down the road fine but when you turn, the outter tie rod ends rub on the inside of the wheel lip since on the pro-comp lift you rotate the tie rod end 180 degrees and it goes in from the top facing downwards on the new spindle. It really limits your ability to turn sharp. It worked for my trip since it was mostly all highway - just have to be really careful not to turn too sharp. I would not recommend it for daily driving as it was really annoying having to back up a time or two just to get into a parking spot without rubbing.
Old Apr 22, 2008 | 11:49 AM
kuruption's Avatar
Would the stock 20" rims and tires work w/ the procomp 6" lift? I'm trying to do my lift in stages to prevent the big dump of cash out of my accounts.
Old Apr 22, 2008 | 08:21 PM
clar's Avatar
You will increase your roll over rate even more than the rest of us with stock tires becouse the stanse is not as wide.
Old Apr 22, 2008 | 08:42 PM
bwd's Avatar
bwd
i wouldn't do it i didn't have factory wheels but i had aftermarket 18's with to much positive offset set and they rubbed bad on my tie rods and dual steering stabalizer, so i opted for 22's to clear all that stuff.
