Lift for 07 FX4 F150??
(In a Nutshell) I have a 2007 F150 FX4 with Donahoe Racing full suspension lift. However I'm not getting the height and clearance I want for off-roading, I need a new lift. I been looking and researching over couple lift kits. Pro Comp-6inch, CST 8inch, Rize, and lastly Fabtech. Whichever I would get would all be with coilovers and shocks. What ideas/opinions do you think would be best??
Go all out bud. Get the CST kit, with all new coilovers and their new Upper control arms. Will beef up that suspension quite a bit, allow for some 37" meats and is probably the highest quality kit out the, not counting custom work.
Or, go with RIZE 8" lift, and King Coilovers or Sway A Way Coilovers and shocks. (RIZE comes with a huge front spacer, to retain stock shocks and springs). But later down the road, I am sure you will be wanting a aftermarket Upper Control Arm kit. I mean, go look at your truck, look at the itty bitty little upper control arms (stock) and the pathetic ball joint. Replace that with a BEEFY Upper control arm, and it also change the Ball Joint to a 1" Uniball (much stronger and allows for more flex)
Thats my opinion if your looking for an "off-road" big lift. Best bet, woudl be a Solid Axle Swap, but thats getting a little much.
Otherwise I would run Fabtech 6" lift, with Dirt Logic Coils and shocks.
if you do a lot of offroading you might want UCA's (upper control arms) i would go with the CST it comes with UCA's, thats what i have. CST is known for there quality. The Rize is also a great kit, no UCA's i think most like it because of the cross member (its flashy and silver), which was a major reason i didnt want it. with both kits i would say get the after market coilover to go along with it.
Oh yeah I forgot one think I'm sure you guys already know what truck it is but my F150 itsn't really stock. I bought my truck a year ago now but its the Baja Special Edition, that's my main concern on going with the 8 inch lift I worry it might ruin the Baja look with to high of a lift.
CST doesn't come with coilovers in there kit you must aftermarket coilovers. Such as kings or fox. What do you guys think between coilvers??Fox?Kings?Racerunner?
^^ agreed. Great tires, awesome looking wheels, decent shocks, CRAP lifts (IMO).
Aluminum rear lift blocks, that make you stack ontop of your factory ones.
Low hanging, weak looking front cross member.
Great for pavement pounders, but if your looking to do some off roading, I would look into Fabtech if your going the 6" route.
What more do you want then 2.5" shocks ??? Thats plenty. And I promise you, Sway-A-Way will have far superior ride quality and off-road ability then anything ya got now. Kings also.
Then add Camburg UCA's in the mic and you'll have quite the rig.
I have the pro comp lift. I agree with mtech that if you plan on doing off roading dont get the pro comp 6 inch. The lift is made for the street. Just look at the set up and you can tell. If you do little off roading the pro comp lift is perfect
Ok then I quess no pro-comp.
Well I am looking for good off-road ride, not to say that donahoeracing hasn't done the job its just not up to what I am looking for. Well I quess its just between CST then Rize and lastly Fabtech. Though I am just in throught that if I do get an 8inch lift it might ruin look of my baja. I have roll-a-long fender flares that came with the truck which i love and give great clearance (why i know 37's will clear easy) but I don't know if that high lift will change it look.
Also to add, I have never driven a bigger truck than a 6 inch lift off-roading are they stable out in dirt?snow?and dunes? If not do you consider getting rear traction bars?
