Lifts?!?
Originally Posted by daculatruck50
Also i only have a 2.5 spacer right now. If i took that off and put the 6" fabtech on i would really only be lifting my truck 3 more inches in the front and 3 inches in the back right? So 33's would look ok. And if i ever wanted to i could just put the spacer on and buy an aal if i ever wanted to go 35's right?
35's are recommended for the 6" lifts. 33's might be a bit on the small side. Don't have to add the spacer to clear the 35's. Most add the spacer back on top to clear 37's.
I know that. I wish i could get 35's i just cant afford them to start with and i can't afford the gas to go with them not. I'm looking into either a 305-55R20 (Preferred) or a 275-60R20 (not unless i have to). I think a 33" will look fine because i saw a member on here that has commented in this thread that had 33" Toyos with 18" MM with the 6" fabtech and it looked sick! exactly what i wanted!! I want the wider tire but money will dictate what i get i guess. Does anyone know where i can get some tires in 305-55R20 cheap. I have looked on the internet and i have found some used ones at good prices. Just wondering.
Thanks,
Trent Kammerer
Thanks,
Trent Kammerer
Yea I did get my lift done at 4WP. I got lucky and spoke directly with the manager through the whole thing. Maybe it was just a bias, because they do push the pro comp stuff. The guy I worked with was pretty knowledgeable and wasn't pushy at all. Maybe I just heard him wrong. My bad on that.
Thanks,
Trent Kammerer
Thanks,
Trent Kammerer
http://orangecounty.craigslist.org/pts/472717924.html
Originally Posted by ThumperMX113
The stores in Florida are pretty damn good ..
This is Florida for ya, this is my guy who does all my work...https://www.f150online.com/galleries...593&anum=11696
Originally Posted by Synergy16
I have a 6" procomp and a 2.5 spacer with 35's and im 2wd and i think only the 4wd can fit 37's with the spacer cause i dont believe i can i would like to though! good luck with what ever you get!
hope you dont offroad or hit speed bumps to fast!!
Originally Posted by bud8817
he was probably trying to get you to go with procomp and made it up, they are really into procomp, i heard once that procomp owens 4wheelpart... ???? idk which is why the push it so much...
I'm pretty sure that pro comp pays 4WP to push their product. Kind of like Midas Muffler shops are reps for flowmaster and push their product. Naturally 4Wp probably gets a kickback from it ( just a like a salesperson for any other corporation). Just plain ole capitalism at its finest.
Pro Comp Lift | F150 | 2WD US $1,288.00
eBay Item number: 260180150932
Seller: 876810895
8-6 pst m-f and 8-12 sat.
mark
209-527-3104
www.northerntire-wheel.com
http://www.northerntire-wheel.com/
They also have the kit for 4WD.
By the way, a sales guy at a 4wheelparts store once told me that they own Pro Comp.
Seller: 876810895
mark
209-527-3104
