Sponsored by: CARiD
Why did my truck come from the factory with the tail end up higher?
Old Sep 13, 2007 | 02:06 PM
Fifty150's Avatar
Old Sep 13, 2007 | 02:12 PM
for increased payload capacity/towing capacity.
Old Sep 13, 2007 | 02:24 PM
Veteran: Army
so it wouldn't look like a chevy
Old Sep 13, 2007 | 02:29 PM
BLUE20004X4's Avatar
Ya, tell me about it. Mine looks like a funny car, but man you can load it up with stuff. I've put around 1600 lbs in the bed (shingle bundles, 21 or 22) and it was a little below level. Rode nice loaded like that. Chevy 4x4's look like a Ford 2wd.
Old Sep 13, 2007 | 05:41 PM
Mine looked like a raccoon, had to level it out!!
Old Sep 13, 2007 | 05:58 PM
ThumperMX113's Avatar
Not to mention, I'm pretty sure it also helps with crash tests.
Old Sep 13, 2007 | 10:18 PM
Fifty150's Avatar
It sure does block out a lot of your vision. I can never see those little sub-compact cars when I'm parking. I have to park by braille.
Old Sep 14, 2007 | 08:55 AM
murraylatham's Avatar
I'm putting in a 3" body lift in the next couple of weeks on an 01 screw 4wd. What size levelling kit would I need for the front end to level it out? Also, would it be harder to install the levelling kit after the body lift is done? Thankis
Old Sep 14, 2007 | 09:06 AM
MSH's Avatar
MSH
Old Sep 14, 2007 | 10:04 AM
jk007's Avatar
All you need to do is crank your torsion bars, a leveling kit is not needed nor is it recommended (I referring to the after market leveling torsion keys). A couple of turns on the torsion bars underneath the truck and you'll be all leveled out. I would advise doing this after your lift because you should get an allignment anytime you mess with the torsion bars. Lift the truck, put your new tires on, crank the bars to eliminate any rubbing on the front end and then get an allighnment. Should should be good to go.
Old Sep 14, 2007 | 10:06 AM
MGDfan's Avatar
Just don't fergit ta re-aim dem hedlites lol
b-b-b-bubba
Old Sep 14, 2007 | 02:12 PM
Fifty150's Avatar
b-b-b-bubba
But that's the fun in having a lifted truck - is that you get to blind the people in little cars. Why else would anyone mount all those extra lights?
Old Sep 14, 2007 | 02:15 PM
mSaLL150's Avatar
exactly, which is why you put HIDs in AFTER you lift your truck.
Old Sep 14, 2007 | 02:22 PM
kingfish51's Avatar
Of course if you do have a load or tow anything after putting on a leveleing kit, you will always be going uphill.
