BDS Lift KIT ?'s
BDS stands for Big **** Suspension. They use to have t-shirts that said "If you want to go deep into the bush, you'll need a Big **** Suspension."
That's enough reason for me to buy their stuff!
No seriously though. BDS does make great products, but I wouldn't use that kit on a F-150 w/o upgrading the spacers to coilovers or the 4/6" Bilsteins. I'm just not a fan of the 6" coil spacers even for pavement pounders; the stock shocks just aren't designed to handle the larger much heavier tires and wheels you're going to install after you get the truck lifted.
I'm surprised that the BDS kit is cheaper than the stage 1 Fabtech kit though. Maybe you should shop around a little because to me it sounds like your shop has some hidden agenda and really wants to sell you BDS.
Some nice features about the BDS kit is that it comes with 5" blocks and a 1.5" AAL for a total of 4.5" of rear lift (you remove the factory 2" block). Also, it comes with stainless braided brake lines for the front instead of some cheezy extension brackets. I paid $117 for Rize braided lines to use on my 6" lift because I didn't want to bend my factory steel lines. Those two items alone are about a $200 value that don't come w/ the Fabtech kit.
awesome replies guys! thanks for all the info...
i am in the process of getting some cash together then its just a matter of clearing two days in my schedule and setting up an appointment...its going to be tough to be without my truck for 2 days...BDS lift it is! i'll post pics when she's done!
Carl
Carl
Carl
Carl
I was looking at just getting a leveling kit, but I don’t like what I’ve read about them thus far. I want a kit that will withstand some beating off roading and not be a true “street queen.”
I just got off the phone with my local 4x4 store...(Tuff Trux LLC here in Rochester NY)...and I asked about a Fabtech 6" lift installed and the gentleman gave me a price of about $3500...but he recommended going with a BDS Lift instead of the Fabtech. He said that a majority of the customers went with either the BDS lift or the Skyjacker. He said that BDS offers a lifetime warranty.
My questions are: How is the BDS Kit compared with the others? Should I pay the extra and get a Fabtech? Or should I get a Skyjack kit? I am on a bit of a budget but all three kind of fit into it. Also, where does everyone order their kits from that are fairly lower in price?
THANKS!
Carl
THANKS!
Carl
THANKS!
Carl
THANKS!
Carl
so with a 6" lift...how much of the yoke is left in the/on the shaft in the transmission? from what i have found extending the yoke seems like a good cheap easy way to prevent some major damage down the road...
has anyone else extended their driveshafts after a lift?
http://www.iedls.com/impala.html
"...As you move the axle aft you are pulling the transmission yoke out of the transmission by an equal distance. When the project is finished and you drive your car there will be no indication of any problem…for a while. Eventually the transmission tail shaft bushing will wear and become the cause of a transmission overhaul. Here is how this will creep up on you.
Pulling the yoke out of the transmission moves the front u-joint aft. This gives the force created by the joint angle a longer lever to use in applying itself to the tail shaft bushing. The now greater force wears the bushing faster opening up space between the yoke sleeve and the bushing. Space between these parts allows the whole front of the drive shaft and rear of the transmission output shaft to orbit. Orbiting instead of rotating increases the wear rate even more. By the time you feel a vibration the bushing is history. As time and miles go by the orbiting drive shaft and transmission tail shaft stress the rear transmission bushing, which then wears. Wear in this bushing allows the centerline of the transmission's internal parts to bow slightly causing everything to wear. Eventually when the clutch packs fail they can take their mating parts with them. You will learn about these internal damages during the transmission rebuild and resulting bill. This whole sequence of events is the completely unexpected result of an innocent, unrelated, parts change..."
