Fabtech Lift Installed w/ Pics
Originally Posted by horde
Street - did you have Fabtech do the work? Truck looks great. You've pretty much got the set up I want for mine.
I had DW Motorsports in Corona do the work. I am very happy with the kit, but do wish the back was about an inch lower. The main thing I liked about the Fabtech is they don't use a spacer, they supply a new shock for the front.
That looks really good..we install about 80% fabtech on F150's where I work and in about 2 months you will need to add either air bags or a add-a-leaf to level the rear end. It looks even better when you do that!!
Thanks for the comments. I might leave it sagged a little, but like you said I can always AAL or something if I wanted to later.
Overall though.... I really like the Fabtech kit. If it wasn't Fabtech I would have gone with the CST.
I thought mine looked good for awhile because when I lifted my truck it only sagged about 1" but it got worse when I loaded a boat and gear in the back for a couple of weekends...My springs have a memory, as do all leaf springs and it does get worse as do all lifted F150's (if you load them up). We have found that the 04's have 1 more leaf then the 06's and I do not know about the 07's yet. I am just warning you...add a leafs are cheap and do not use them untill you have to. If you are not hauling anything then you are OK.. Your truck looks awsome by the way!!!!!!!
