Sponsored by: CARiD
Leveling kits, 2" vs. 2.5"
Old Mar 22, 2007 | 11:35 PM
  #31
JohnBoy88's Avatar
I think the basic rule of thumb is 2" looks better on the 2WD and 2.5" is better for 4WD because the back end is higher on 4x4s.
At least that's what I have determined.
Originally Posted by _cashel
Hah that's pretty cool, I graduated from there last year. I'm sure we've seen each other around then. Thanks for the help though man.
Interesting. That's pretty cool. No problem man.
Old Mar 23, 2007 | 05:01 PM
  #32
ski's Avatar
ski
Registered User
I just put the 2.5 AS on my 05 4x4 and it put the front end up 1/4 higher then the back. I put the 3inch block in the back and now the front is 39 1/4 inches to fender well and the back is 40 1/2 inches to fender well. The front lift ended up being 3 1/4inches. I'm getting some 35x12.50x17 Cooper ST's tomorrow. If it's not raining too bad I'll post some pics.
Old Mar 23, 2007 | 09:52 PM
  #33
Shane1's Avatar
Originally Posted by F150FXOnline
Shane1 nice pics on the before and after front lift kit!
Im about to install one myself and helped me a lot of getting an ideal on what it would look like. I just bought 325/60/18 and hope to get them installed after the AS is installed.
Im trip'n about tire size ! I'm still running stock until my rims get in. 325/65/18 is what the my tire guy is suggesting as well....seems a bit wide. Please post some pics when you get yer tires...
Old Mar 23, 2007 | 11:11 PM
  #34
F150FXOnline's Avatar
Yeah I just got my 325/60/18 tires today!
SO I have the rims and tires and the 2" AS kit should arrive Mon-Tues. I agree the tires seem VERY wide and hope they fit! I made post in the tires forums about having the weights installed and asked others/wendell about the offset and backspacing to see if I should have any issues. Im being told I shouldnt by reading but after seeing theres not much room now between the stock rim/tire from the inside im starting to 2nd guess. hehe
I'll post picks when done. Also if you like I'll go out and take some of the tires in the garage. When they arrived I thought they were the wrong size they were so big but more wide then I thought theyd be. Im just keeping my fingers crossed they will fit with no problems!!!
Old Mar 24, 2007 | 01:06 AM
  #35
Shane1's Avatar
Yeah take some pics of the tires, what kind of rims did you get? I think I'm gonna email or pm wendell and see what he says. I'm confused on how you get the conversion mm to inches for over all hieght of the tire . Maybe someone will see this and chime in.
I understand how to convert mm to inches but when I put all the numbers together I don't get what I would expect
Old Mar 24, 2007 | 01:12 AM
  #36
nd041189's Avatar
i just put on my 2" AS on the passenger side earlier....i will have the drivers side on early tomorrow morning. looks good so far!!!!
Old Mar 24, 2007 | 09:55 PM
  #37
nd041189 howed it go? fisnished? Also what size tires you putting on?
Old Mar 26, 2007 | 03:24 AM
  #38
DracoF150's Avatar
Just installed the AS 2.5 kit today on my 2WD. Took about 45 minutes on driver side and then 30 minutes on passenger side. Looks good...will get pics up tomorrow.
Old Mar 26, 2007 | 01:33 PM
  #39
DracoF150's Avatar
Here is my 2wd version with the 2.5 AS kit. Put it on yesterday in 1.25 hours. Very simple!!! Also the truck is sitting on 24" TIS with 305-35-24 BFG's...35" tires coming soon!!!
Old Mar 26, 2007 | 01:36 PM
  #40
DracoF150's Avatar
Measurements are 39" from ground to fender in the front and 38.75" in the rear. Might go with AAL later on...
Old Mar 27, 2007 | 09:41 AM
  #41
onyx_rock's Avatar
Here are before and after shots of my FX4 with 2" AS. I think it sits perfect and the 2.5" might have been a little higher in front if I went with it.
BEFORE
AFTER 2" AS
Old Mar 27, 2007 | 10:09 AM
  #42
Shane1's Avatar
It's funny how things work out...I was just sitting here thinking about tire size, the 285/65/18 to be exact and presto...Onyx hooks it up! Could you get a measurment from the ground to fender? Do you have any front or rear shots? I hope Chris Hansen doesn't see that last sentence...
TRUCK LOOKS GREAT!
TIA
Shane
Old Mar 27, 2007 | 10:27 AM
  #43
onyx_rock's Avatar
Heres a front shot. I dont have a rear. I can take measurements for ya this evening.
Old Mar 27, 2007 | 01:26 PM
  #44
Shane1's Avatar
Thanks!
It would be great if a good tire maker made a 285/70/18 but I haven't found one yet!
I'll be waiting for your measerments
Shane
Old Mar 27, 2007 | 01:55 PM
  #45
YOMAN's Avatar
onyx_rock,
Is that flat or gloss black ? how much did it cost you?
i was planning to do powderocating for my FX4 !
Any info/detail will be helpful.
ThaNKS!
yoman!
